A3 8l '98 Help,Temperature Gauge not working.
seafar99 Nov 3, 2013
  1. seafar99
    seafar99 Member
    45
    Howdy folks, my (A3 8l 1998)temperature gauge seems to have stopped working. I'm still getting warm air in the cabin but not exactly that hot that I need to turn the temp setting down. Currently set it at 29 degrees and it's warm not unbearably hot. It also takes a while to get warm. The temp gauge isn't going up at all.
    What do the experts think?
    Thermostat? Or Temp Sender Unit? Possibly both?
    Any help opinions, Thanks.
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    id say stat for the low temp heat
    and maybe cts for the non working gauge
    or maybe a ****ed gauge
  3. seafar99
    seafar99 Member
    45
    Thanks,I'll start with the thermostat, anybody got a location photo of the housing ?
  4. robin_bga
    robin_bga Member
    50
    I would think before you remove the thermostat, first try switching on the AC, if fans come up then I don't think its the problem, I think u need to check the radiator switch.
    However, the stat is located under the battery.
