a3 8l 1.8t, perfect base for modification
mr-bongo Oct 10, 2012
  1. mr-bongo
    mr-bongo New Member
    19
    a3 8l 1.8t AGU sport w reg 115,000 in march this year had brand new vr6 clutch and single mass abf flywheel lightened to 7.5kg, had new slave cylinder also fitted ,at the same time had full service new filters ,plugs, castrol magnetic, was also de sludged which if not done can be the death of 1.8t's had new oil pickup and seals since this work it has only covered just over 1,000 miles so the clutch has barely been broken in, in july brand new raceland coilovers were fitted its never been run stupildy low so theres no sump/subframe damage, de wipered rear,
    has digital climate control,which works very well ,its had custom stealth sub install with custom fibreglass sub box with a 10" rockford forsgate punch p2 ,alpine amplifier,which is behind the rear door card the cd changer has been moved to under the glove box as the sub is where it used to be which means you can change the cd cartridge without getting out of the car also had a auxillery input installed with a dre beats cable the sub is also on a switch so it can be turned off when required, the interior is in very good condition ,no rips no stains no burns this is a very clean car and runs well, has no problems, all pads and discs are in good condition aswell as the tyres haynes manual included,jack,wheel nut bar aswell, if you dont want the sub i will knock some money off, thanks
    tax,mot til end of december only advisory last time was anti roll bar bush, 40 pound at most to have replaced
