A3 3 door seat belt buckle change
quattro rob Jan 25, 2010
  1. quattro rob
    quattro rob Member
    84
    my passanger seat belt buckle is broken just bought a complete new 1 and want to change the whole lot as my other 1 is bend from putting the seat forward and then down as it goes backwards etc, any help on how to do it would be nice thanks,
  2. Chris_Q
    Chris_Q New Member
    Hi Rob,
    I have the same issue, am about to change the seat belt anchor buckle bit on my 3door '99 A3. I believe the pretensioner is on the reel, so no issues there, but...do you need to take the seat out, disconnect anything?
    Any help would be greatly appreciated if you find any info,
    Chris
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    as the other seat belt post disconnect the battery,,,
  4. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,246
    189
    Remove the rear panel, you can then see the reel in the bottom of the B post. The anchor point is held on by a 17mm bolt one end and a 8mm iirc allen key bolt behind the panel. You can undo the allen key bolt and just about slip the belt off the anchor.
  5. Chris_Q
    Chris_Q New Member
    Thanks for that, but it's the side on the centre of the car, the red and black catch? that the belt clips into when you put it on. Do I need to take the seat right out or can it be done by tilting the seat or sliding it forwards somehow?
    Ta
  6. AudiLeon
    2,246
    189
    The seat is very easy to take out anyway fella. Just pop it out.
  7. Chris_Q
    Chris_Q New Member
    Okay, almost all sorted, but the combination of a soft bolt head and huge quantities of Loc-Tite meant that the bolt became rounded off and required a pair of mole grips to remove...but we got there! Anyway, the new bolt and washer have cost me the grand total of 96p from my local Audi garage who after I emailed them last night, actually called me back today and have ordered it ready for collection tomorrow...TIDY! So, after tomorrow evening, I shall once again be able to carry a passenger in the front! Thanks for the help guys, much appreciated!
