a3 3.2 v6 dsg quattro sport 2004 help needed
shariain Dec 17, 2011
  1. shariain
    shariain Well-Known Member
    1,182
    190
    hi
    i have just bought a A3 3.2 v6 dsg quattro sport and i am unsure of a few things and would like help and advice from people who have a better understanding of the car.
    1st think is the car idles @600rpm roughly (seems a bit low to me would have thought it should be about 700-800rpm)
    2nd it seems to have a shudder/hesitation when coming to a stop (the sort of thing you get from a manual car before it stalls might be linked to the 1st issue)
    3rd there doesnt seem to be a siren when the alarm goes of the indicators flash but no noise (the horn works fine and if you have not shut the door right and set the alarm there is a warning siren goes off to tell you the doors not closed right)
    4th the steering warning light comes on in the dash but goes off seems to be very intermittent (cant find the power steering fluid reservoir)
    thanks in advance for any help
  2. willowsdad
    willowsdad Sideways
    1,027
    32
    I'm certainly no expert but I've had my manual Quattro sport for a few months now and that does seem a bit off. Mine idles like you say about 800 I think, you haven't used regular unleaded have you? I done that when I first bought mine and it ran awful. Mine also has a siren when
    the alarm goes off. Hope you get it sorted soon, it's a cracking car.
  3. wez3570
    wez3570 Member
    704
    20
    Mine idles @ 600rpm but not roughly
  4. wez3570
    wez3570 Member
    704
    20
    I had this problem, was fixed after I had a full alignment.
  5. shariain
    1,182
    190
    Sorry I didn't mean roughly as in rough idle was meaning @600rpm approximately but on saying that there is a slight bounce on the rev needle.
  6. shariain
    1,182
    190
    Loving it
    I will get it sorted under the warranty as I have 30days failing that I got 1 years warranty when I bought the car so hopefully that will cover it.
  7. wez3570
    wez3570 Member
    704
    20
  8. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,279
    166
    You need to get a VCDS print out but assuming all is well get them to raise the tickover a bit and it may stop your judder when stopping. DSG's tick over slower than manual but 750 would be better than 600.
    A VCDS scan will show a fault in the alarm of if its been turned off
  9. shariain
    1,182
    190
    What is vcds is that vagcom
    Thanks for the replies I will have a look at the thread in the post above when I'm home. Thanks again
  10. paddy
    5,279
    166
    VCDS=vagcom sorry :)
  11. -Ju-
    -Ju- Well-Known Member Team Panther VCDS Map User Audi S3
    2,356
    472
    My advice would be NOT to read that thread lol! seriously though try and get the later software update on as this cures a lot of niggly running issues.
    Great car though and sorely missed, although my mate has one and keeps teasing me with the noise :sob:
  12. shariain
    1,182
    190
    Do I just go to the dealer and ask them to check the software version on the car and update it if required.
    That noise is special.
  13. -Ju-
    2,356
    472
    That would be too easy! The dealers have in general been very reluctant to the point of ignorance in doing any updates although some have been lucky and had no trouble.
    There is however a recent tpi that includes the required software update so should be easier now to have done, it will cost however depending on the dealer.
    This is it:-
    The tpi number has now changed to 2010289/3 (it also worded gearbox judder poor acceleration when changing gears at high revs, but the update is the same sw version)for those dealers struggling to find the original tpi which has been removed from elsa pro and elsa win
    svm code for the update is 8P01A005
    CD UPDATE DISC 4F0 906 961 N
  14. paddy
    5,279
    166
    There must come a point where some of these cars have already had the update......I am amazed my 3.2 has not turned up on this forum yet :)
  15. Spider
    Spider Member
    50
    My mkv R32 idles at 630 rpm
    As for the steering fluid mine is electric so yours night be the same
  16. shariain
    1,182
    190
    Where is the best place to buy vcds from I take it the ones on eBay are no good.
  17. wez3570
    wez3570 Member
    704
    20
    Nigel (forum username NHN)
    He's the man for all things OEM retrofit. He can supply and install most options.
