A3 3.2 Perished breather diaphragm - whistling sound from hole in rocker cover
VagPro Jun 24, 2013
  1. VagPro
    VagPro Active Member
    444
    34
    Hi guys,
    2006 A3 3.2 dsg Quattro engine code bmj
    I am getting a whistling sound from the small hole in the rocker cover, took the cover off and have found that the rubber diaphragm on the breather assembly is perished and cracked.
    I have a part number 022 103 515A for the breather assembly but the dealers are saying its part of the rocker cover (£160+)
    Any ideas / experience ?
  2. autolatry
    autolatry Active Member
    347
    67
  3. VagPro
    444
    34
    It sits in the bulge in the rocker cover :(
  4. Chillout
    Chillout Active Member
    610
    50
    I had to do this it's a pain don't run it you can wreck your engine http://sandbox.enjoybeing.net/veedub/vw_vr6_self_study.pdf
    if you run your car it can apply the full intake vacuum to the crankcase lifting the oil either hydro locking the engine or causing damage due to lack of lubrication it's a really expensive considering the part it's self looks like £20 to £30 pounds tops .
  5. VagPro
    444
    34
  6. Chillout
    610
    50
    its the address of it it's quite good I am not the best with technology.
    cyclone oil separator page 26/27 but not available on its own
  7. VagPro
    444
    34
    Ahhh I'm with you now, when you said "I had to do this" I thought you had a guide to repair it.
    Unfortunately can't find the part anywhere as its part of the rocker cover, I'm gonna see if I can make up something or will have to fork out £200!
  8. Chillout
    610
    50
    I wouldn't risk it i took the front end off but supported the rad so nothing was disconnected ,intake ,throttle body,air box have to be removed.
  9. VagPro
    444
    34
    Mines fully stripped out, did you have to replace your separator then? Or did you change it including the rocker cover ..
  10. Chillout
    610
    50
    Yes I had to change the whole cover I tried via audi and tps to get it on its own but its not available on its own it comes in the cover along with the gasket it's quite a precise part regulating the vacuum an different ranges of induction.
  11. VagPro
    444
    34
    Cheers, ill order a complete cover from tps tomorrow
  12. VagPro
    444
    34
    Hi chillout,
    What do you think of this, I was searching online and came across this for the 2.0T FSI engine
    Crankcase breather A4 2004-2012,
    So went to Sanburn to see if he had anything similar, found the orange diaphragm inside the breather above (from a BWE engine)
    Its slightly thicker and the spring that came with is is shorter, I was thinking to give it a go with the longer spring from the original 3.2 engine.
    (I know I should order the complete cylinder head cover, but I'm being a tight git lol!)
  13. Chillout
    610
    50
    It's a lot of trouble to go to but I can see the potential not sure if its worth the risk and the time to strip if it doesn't work properly.
  14. VagPro
    444
    34
    I see your point, looking at this:
    It appears that the function of the diaphragm is only to act as a sealing interface, which would mean that the pressure is regulated by the length (stiffness factor) of the spring
    Given the above I will give it a go with the orange diaphragm.
    (I've bypassed the rads at the moment so don't need to put the front panel on, hence not that much work involved...)
    Keep you posted on how it goes ....
    (Yes I like to live on the edge lol)
    autolatry likes this.
  15. Chillout
    610
    50
    Very Austin powers .
    you can only but try worst case it doesn't work and your £200 down but hey the glass is half full
  16. VagPro
    444
    34
    Hey Chillout
    Fitted the diaphragm from the 2.0TFSI engine and she idles perfectly fine. It's useful to note that the spring from the 3.2 is longer and given how much it's compressed, this plays a bigger part in regulating the pressure.
    So all done now :)
  17. M12RJX
    M12RJX Member
    199
    i think i got the same problem on my car! not sure but iv noticed when car is idle it does make a whistle/chiming sort of nice from the left side of the engine bay. not got it checked just yet but wondered how much would something like this cost to get repaired?
  18. VagPro
    444
    34
    The is a small hole in the rocker cover above where the plastic hose connects, that's where mine was whistling from. I believe if the diaphragm is perished the engine operates under full intake manifold pressure which is bad !
    You cannot buy the cyclone oil separator by itself so would have to buy the rocker cover, or do what I did and use a diaphragm from an oil separator from a BWE engine.
    You will have to take off the intake manifold and rocker cover, that means either putting the front panel in the service position or taking it off.
  19. M12RJX
    M12RJX Member
    199
    i am not mechanically minded at all mate! lol im rubbish when it comes to things like that. for something like this how much would you say it would cost me to get repaired if i went down the route you have. im not 100percent its the same thing as yours but if it is thanks for ur help. i went on lunch and the noise was gone! so really not sure !
  20. VagPro
    444
    34
    It would take me about 8 hours to do it all. Plus the cost of parts, where your mechanic may want you to get a new rocker cover, or you could just change the diaphragm as I did.
  21. Paul Waterfall
    Paul Waterfall Member
    33
    I know this is an old post, but I`m having the same trouble on my 2.0l fsi a4 2003 with the breather system. I came across this diaphragm for the valve cover.
    http://www.ebay.co.uk/itm/Diaphragm...r_Truck_Parts_Accessories&hash=item2a35bafc18
    Paul
