A3 3.2 Jump Start Help!
youstolemyname Dec 30, 2010
  1. youstolemyname
    youstolemyname Member
    31
    Well the missus' Clio refuses to start after not being used for a number of weeks because of poor weather :( It was literally buried in snow till the thaw.
    Went to give it a jump and found the battery on my car is in the boot, under the spare and a riveted down panel! Are there any posts under the bonnet to connect the leads to to save unscrewing all the stuff underneath? I couldn't see any for the life of me...
    Thanks for any help for an Audi Newbie :)
  2. paddy
    paddy Audi=No fault code, no idea
    5,152
    133
    Its at the back on the right hand side under a cap as you stand in front of the bonnet. about the highest point.
  3. youstolemyname
    31
    Found it, thanks. Page 346 of the manual for anyone else who ever might need it. There is a nut and a prong (Which should be covered but in my case was not) as Paddy said in the top right of the engine bay.
  4. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,227
    319
    bmw's have the same thing battery in the boot and a positive terminal under the bonnet with a + sign on it
  5. paddy
    5,152
    133
    Strongly recommend you get a cover as soon as poss mate. when the bonnet is shut that live terminal is very close to the bonnet and a Small front end knock could bow the bonnet down and you will have a short and fire !!
  6. youstolemyname
    31
    Eek- Where can I get the cover from? Anyone know the part code?
  7. FranA3
    7,227
    319
    your best bet would be audi mate shouldnt be that expensive i wouldnt have thought cant help on the part no soz
  8. JonRola
    JonRola Member
    My pos cover broke very easily when opening it - cheap non heat-resistant plastic?
    There is no neg (ground/earth) provided and finding a good neg contact wasn't easy. I found an earth strap down the right side (from the front) of the rads but it's awkward to get at. Any other earth was to resistive to crank the 3.2L engine. I actually had to use tractor jump leads to get my car started. A good neg terminal like the pos terminal would be very handy.
  9. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,195
    381
    Thought there was an exposed earth point on the inner wing near the positive one, looks like a bolt stuck up. Are you saying that you can't get a good contact from this?
  10. mike foster
    3,967
    Looks like you can't just buy the cover !
    The whole unit is called 'Potential Distributor' part no. 1K0 937 517 and is about £35 !
