A3 2010 Sportback Black Edition Bluetooth
DazNoonan Feb 19, 2014
  1. DazNoonan
    DazNoonan Member
    34
    Maybe an easy one this... Will this car be fitted with Bluetooth as standard? It's got standard headunit.
    I'm picking the car up tomorrow... If it's not standard is there a way to check for it and also how much roughly would it cost to get something fitted?
  2. MorkC68
    MorkC68 Stationary
    171
    27
    Mines got it fitted - best way to check, go & do a Bluetooth search & you'll find one called Audi_hv or similar! this should be your Bluetooth connection!
  3. DazNoonan
    DazNoonan Member
    34
    Was it part of the standard equipment do you know or will it be some have it and some don't?
    Also so when I pick it up start the car the search from iPhone and see what happens?
  4. MorkC68
    MorkC68 Stationary
    171
    27
    Dunno if it's part of the standard equipment, I think it was on the BE's.
    Yep do the scan from your iPhone, mine worked a treat - not sure of the pairing code though, it may be 0000 or 1234, the manual will tell you :)
    DazNoonan likes this.
  5. MorkC68
    MorkC68 Stationary
    171
    27
    Just checked, mobile phone perpetration - low is part of the std spec for the BE's, you should be good to go!
  6. lgooch
    lgooch Well-Known Member VCDS Map User
    1,202
    170
    Work colleage has a 10 plate BE and no Bluetooth. Not sure when it became standard
  7. DazNoonan
    DazNoonan Member
    34
    Hmmm some confusion then... Would be good to have to. I wonder if it became standard the sametime they changed the wheels etc...?
  8. lgooch
    1,202
    170
    He has the old style 7 spoke alloys in titanium. Also his steering wheel didn't have a silver ring in the insert around the Audi badge.
  9. MorkC68
    MorkC68 Stationary
    171
    27
    I'm sure the Audi brochure I looked in was for 2011 model year, it certainly wasn't earlier than that. Best bet, pop out n have a scan :)
  10. DazNoonan
    DazNoonan Member
    34
    Yeah one I've gone for has the same wheels...
  11. DazNoonan
    DazNoonan Member
    34
    Yeah like I said im collecting tomorrow... Also know to scan for audi etc... So thanks for the info.
    MorkC68 likes this.
  12. MorkC68
    MorkC68 Stationary
    171
    27
    No problem - I'm not as clued up as the guys on here, just know how mine works :) old vw's are more my thing!
  13. lgooch
    1,202
    170
    You might have been lucky and whoever owned it could have specified it on the build. Not too expensive to retrofit if you need it anyway. The Audi system is very good indeed. Better than any aftermarket solution i have used in all my cars
  14. A3Kent
    A3Kent Well-Known Member
    1,571
    249
  15. lgooch
    1,202
    170
    This is MY2012. Mr six has bought a 2010 model. I have a 2012 model car and it has Bluetooth as standard as per your bulletin. He does not even have the same wheels
  16. MorkC68
    MorkC68 Stationary
    171
    27
    I hope mines not a 2010 :eek: mines the 2012MY with Bluetooth & the rotors as standard - its Daz that bought the 2010 :)
  17. lgooch
    1,202
    170
    Ah. Sorry doing all of this on an iPhone ! Apologies. Comment still stands though
  18. S Liner
    S Liner Member
    72
    15
  19. lgooch
    1,202
    170
    That's all correct. I started looking or my BE when 11 plates came out and they started fitting the rotors half way the through MY11 if I recall. At this point they also started fitting BT low and I ended up opting for BT high which includes the cradle in the arm rest and voice control
    OP could be lucky. Only one way for him to find out
  20. DazNoonan
    DazNoonan Member
    34
    Thanks for all the info... will do as you said tomorrow when I have started the car and search for Audi - Hopefully I am lucky!! If am not for any reason how do I go about getting bluetooth fitted (audi genuine one) and roughly how much would it cost? I know I won't be able to fit myself as I'm not really good with things like that...
  21. S Liner
    S Liner Member
    72
    15
  22. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Bluetooth was deffo optional until 2011 when it became standard.
    Mine is a MY11 60 plate BE with rotors and it didn't have Bluetooth :)
  23. 964kevin
    964kevin Member
    109
    my 09 BE had bluetooth as standard, I did not spec it, it is also standard on my 11 plate, again I did not spec it.
    K
    RobbieWebs likes this.
  24. RobbieWebs
    1,031
    249
    Hmm strange that as I found old brochures and it said it was an option and not standard ...
  25. lgooch
    1,202
    170
    Sometimes already included as part of a tech pack or something. I.e. You ask for sat nav and it gets thrown in. Just a thought I could be wrong
  26. Sidhu88
    Sidhu88 Active Member
    808
    76
    Make sure u search within the first few mins of starting up the car otherwise it might not pick it up.
  27. DazNoonan
    DazNoonan Member
    34
    Will do... Thanks for the heads up.
  28. RobbieWebs
    1,031
    249
    Well does it have it or not?
    Lol :)
  29. DazNoonan
    DazNoonan Member
    34
    Just got home from collecting it and nope no Bluetooth installed.
  30. lgooch
    1,202
    170
    Damn. Trip to NHN for you !
  31. DazNoonan
    DazNoonan Member
    34
    Yeah already emailed him for some prices... I do need the Bluetooth so will have to get it sorted.
  32. lgooch
    1,202
    170
    The OEM BT is excellent as well. Worth the extra money over an aftermarket kit IMO
  33. RobbieWebs
    1,031
    249
    How are u enjoying the car?
  34. DazNoonan
    DazNoonan Member
    34
    Loved the drive home Robbie. Got home around a couple of hours ago had some food then just realised I must go for another drive so just got back. Love it...
  35. lgooch
    1,202
    170
    What model is it. Diesel or S 3
  36. DazNoonan
    DazNoonan Member
    34
    Diesel 170
  37. lgooch
    1,202
    170
    Nice ! I just wish I had those extra horses
  38. RobbieWebs
    1,031
    249
    Glad ur enjoying the car :)
    I'm in the same boat as Igooch, I wish I had the extra horses.
    Nothing a remap won't sort out tho :p
  39. 964kevin
    964kevin Member
    109
    Possibly, my first 09 did not have anything extra, my 11plate has a tech pack, auto lights, cruise, windscreen wipers etc.
    I didnt know this was installed until I read a thread here 3 years ago that mentioned doing the bluetooth search when the ignition was first turned on......
    Kevin
  40. RobbieWebs
    1,031
    249
    I still haven't fitted it to mine as I'm not in the car long enough.
    Nice thing to find tho if u didn't expect it :)
