You need the speakers, wiring & sub (as the amp to drive the rears is inside the sub). No Audi HU can drive the rears without an amp. They only have an internal amp for the fronts.
No what I mean by drive is that the chorus II+ cannot even support the amp, it doesn't have rear line levels either. So a concert II+ is required to feed the rear line levels to the amp.
Wiring is not easy unless you have the entire rear/sub woofer loom. It needs to run from the boot to the HU and then you need to tie it into a 12v feed. Far easier to just install an aftermarket HU which can drive the rears directly.
