A3 2007 Heated Seats
rlaw Nov 13, 2012
  1. rlaw
    rlaw New Member
    hi all,
    I recently bought an A3 2007 from a dealer. The dealer mentioned that the front seats are already built-in with heated element but only haven't hooked up and put the switch and control dial on the climate control panel. Currently, the switch location where the heated switch should be has a solid black cover. I am wondering is there anyway I can check the seats are heated ready ? if so, can I hook it up myself if I can buy the switch and the dial ?
    your help is much appreciated and Thx you in advance ..
    regards
    Rico
  2. audicruiser
    audicruiser Audi Heaven
    1,865
    They won't have the heating elements in the seats... If the car wasn't specced with them from new then you will have to do the complete install...
  3. rlaw
    rlaw New Member
    Hi Scott,
    Thank you for your comment. Is there anyway I can check? like open the climate control panel??
    Regards,
    Rico
  4. RallyX
    RallyX Flat Out VCDS Map User
    143
    Typical car dealer, he was LYING to you.
  5. audicruiser
    1,865
    Believe me, you will NOT have the heating elements in your seats. Audi do not fit something to cars that won't be used. Thats why heated seats are a £350 option...
  6. _G_
    _G_ Active Member
    876
    37
    second / third that you dont have them
  7. SootySport
    SootySport Well-Known Member Team Silver
    2,865
    763
    Again, dealer told you porkys. To fit retrofit will cost more than the original £350 and a lot of work.
  8. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I'm sure I read another thread with a few members mentioning that some seats do come with the elements already in?
  9. Mikemc
    1,024
    37
    I just checked under my black cover, I have 3 connectors can any body tell me what they are? Surely you only need 1 for airbag and 1 for adjustable lumber?
  10. audicruiser
    1,865
    The other is for the seat belt...
  11. Mikemc
    1,024
    37
    Doh!
