a3 2000 front fog lights question
Bellic Dec 21, 2006
  1. Bellic
    Bellic Member
    265
    i have a 2000 a3 on the headlight switch i have the front fog function which lights up green as normal but i do not have front fogs is this normal ?
  2. Jaywoo_A3
    Jaywoo_A3 Member Audi A4 Audi Avant Owner Group S-line owners group
    542
    Yes, the switch must have been replaced a some point with the added position on it.
    dont worry about it i had to change mine because it broke and i got one off ebay with front fogs on.
    It only lights up, behind it there is no wire in the multiplug.
    It always good to know if you ever want to put the fog lights in,that you havent got to buy a new switch.:yes:
  3. Bellic
    Bellic Member
    265
    ok cheers mate
  4. nick1973
    nick1973 Member
    111
    im fitting fogs does that mean that i only have to contect themto the existing wiring and buy a new swicth??
  5. Quattro_Lew
    Quattro_Lew All Torque
    206
    are u sure? i thought front fogs were standard on TQ's, mines a 2000 and has them, pre facelifts are built into the headlight as opposed to facelift lower ones
  6. Bellic
    Bellic Member
    265
    i think mine must have had the old units which had built in fogs , someone must have put the facelift ones on mine as mine has the early rear lights aswell
  7. Bellic
    Bellic Member
    265
    quattro lew is your clutch pedal a bit hard to press ?
  8. Quattro_Lew
    206
    i wouldnt say its really hard, but compared to my last clutch it is heavier with it being a performance car, you could have an air lock thats causing a bit of extra pressure making it harder to press down
  9. Bellic
    Bellic Member
    265
    have you had a new clutch?
  10. Quattro_Lew
    206
    i dont think so, ive only just bought mine in october, i think its still on standard clutch atm
  11. Bellic
    Bellic Member
    265
    can you hear the turbo on yours , mine is quite i think as it is k03?
    have you done any mods to yours quattro lew
  12. Jaywoo_A3
    542
    No, you will stil need to get a wirng loom and a relay for the fog lights like any retro fit fog lights, it just means you will be able to use a OE audi switch instead of cutting one into you dash.
  13. nick1973
    nick1973 Member
    111
    thanks will nip and get a loom form somwhere
  14. Quattro_Lew
    206
    yes i can hear the turbo on mine, its still standard i havent had any money to buy things for it :(
