A3 2.0tdi - leak from fuel pump & diesel in engine bay
M005 Oct 3, 2012
  1. M005
    M005 New Member
    Picked up an A3 2.0tdi on Monday and it has a fuel leak from the top of the fuel pump under the bonnet.
    This has led to fuel splashing all over the engine bay - car is back at the garage I bought it from (a Merc main dealer) to be sorted.
    Am I right in thinking the auxiliary belts will need replacing as they will have been contaminated with the fuel?
    I'll obviously expect them to steam clean the engine bay & anywhere else covered in diesel.
    Anything else I shoul dbe getting them to do / check?
    Thanks.
  2. Kohaku
    Kohaku Member
    196
    27
    Are you sure any gaurantee's haven't already run out.
  3. M005
    M005 New Member
    Dealer has just called and said they have replaces O ring on the fuel filter and are going to keep it over night & give it a run to check it has solved the problem.
    They have also steam cleaned everywhere.
  4. Wats-on
    Wats-on New Member
    22
    So is it the fuel filter or fuel pump that was leaking?
    I had the high pressure pump gasket go and that was leaking diesel and making the car smell awful.
    The gasket cost under a tenner and its about an hours labour.
  5. M005
    M005 New Member
    I thought it was fuel pump, but maybe fuel filter is on top of fuel pump?
    Front left of engine bay next to the washer bottle, has 4 (IIRC) pipe going into the top.
  6. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    That's the fuel filter.
