A3 2.0TDi DSG Wet Clutch?
alpesh26 Feb 19, 2014
  1. alpesh26
    alpesh26 Active Member TeamMisano
    400
    35
    My dad is after changing his mk6 Golf 1.6TDi DSG for an A3 2.0 TDi DSG. Does anyone know if the A3 uses a wet clutch system?
    The golf 1.6TDi uses a dry clutch system which is too snatchy and is eating the clutches. It's already had a new pair of clutches fitted, mechatronic and a new gearbox (under warranty) but the problem has come back so it's time to get rid!
    TIA
  2. NHN
    29,328
    1,708
    On the newer stronic boxes they're dry afaik, the older dsg boxes are wet.
    There has been a recall for some stronic boxes, recently aswell iirc.
  3. alpesh26
    400
    35
    ah cheers, the car he's looking at is a 2011 (61 plate). Do you know when they all went to dry clutches?
  4. nluk100
    nluk100 Active Member
    935
    168
    43
    Was it a 6 speed or 7 speed in his Golf? Being a Mk 6 it must be fairly new?
  5. alpesh26
    400
    35
    The golf is a 7 speed on a 2009 - 59 plate. I'm going to get him to call the garage and find out if the A3 is a 6 or a 7 speed box, i'm under the assumption that the 6 speeds will be wet clutch - please could someone confirm?
  6. Sayam
    Sayam Well-Known Member VCDS Map User
    2,703
    631
    My understanding was all the diesel S-tronic boxes were wet plate as this leads to a higher torque handling capacity? I could be completely wrong though. Again, as far as I know all the 2.0TDi S-tronic boxes are wet plate.
  7. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    All 6 speed DSGs have wet clutch.
    The 7 speed ones come with both dry and wet clutches.
    The first 7 speed boxes were installed on smaller engines, like the 1.4 122 TSI, 1.6 TDI, 1.2 TSI and have the dry clutch.
    Since 2010 IIRC, there are new 7 speed boxes with wet clutches but these can be found on bigger engines and I think they are for 4wd cars. You can find them in the newer A4, A5, Tiguan etc.
    So, the 1.6 TDI Golf has the 7 speed dry clutch gearbox.
    The 2.0 TDI A3 has the 6 speed wet clutch gearbox.
  8. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    If you have access to VCDS, It'll give the model of DSG/S-Tronic box fitted.
    From there I'm sure you'll be able to find the definitive answer to the question.
  9. alpesh26
    400
    35
    Thanks lads! I take it I just need the gearbox code and do a quick google to confirm?
