a3 2.0tdi blip power
j50sho Jul 20, 2010
  1. j50sho
    j50sho Member
    32
    hi guys, currently on-going problem which im getting help with from nigel... my car blips in power in all gears every so often, fault code threw up a maf problem which i replaced, the replacement did help but i still have the blip normally around the 2k rev point, one thing i noticed is when i first start the car in first gear when i reach about 1800rpm the car chugs (if thats the right word) .. got no fault codes up now .
    should i check for leaks or possible fuel contamination?
  2. navnayyar
    navnayyar Member
    756
    have you checked map/thrust sensor?
  3. j50sho
    j50sho Member
    32
    replaced the maf mate.
    one thing ive also noticed, when i had it remapped the guy showed me in the gears it rev'd to 4000rpm, now it only reaches 3000... dont know if that is saying anything
  4. navnayyar
    navnayyar Member
    756
    im not talking about the maf, map/thrust sensor is different is common fault in these tdi's
  5. V16
    V16 Member
    214
    where is the map/thrust sensor located? i replaced my maf but still a slight jerk now then, unplugged the maf and it drove like new!
