A3 2.0T TFSI engine cover
timontour Dec 2, 2012
  1. timontour
    timontour Member
    37
    I broke my plastic engine cover getting it off, pig of a thing to get off also the plastic pivots that it sits on had broken off
    i managed to get some new pivots from VAG 8 quid and a guy on ebay is selling a cover off a 2011 2.0 TFSI
    mines a 57 plate, does anyone know if the cover will fit mine or have they changed? mine is the square shaped one with the air filer built in.
    thanks
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Check if yours has air filter built in. Newer covers without the air filter will not fit.
  3. Minstadave
    Minstadave Member
    560
    19
    By plastic pivots do you mean the rubber stoppers that join the cover to the mounts on the block?
  4. timontour
    timontour Member
    37
    yes mine has the air filter built in, are the newer one different
  5. timontour
    timontour Member
    37
    no not the rubbers, the pivots that the rubbers push onto both the ones at the back had perished they screw into a heatsheild
  6. timontour
    timontour Member
    37
    i mean these pivots, the 2 at the back marked in red had crumbled, i have replaced them already it's just the cover i need now
  7. MrLapou
    1,233
    121
    Mk5 Golf GTi use the same system.
    Newer engines have totally different cover, but I believe (correct me if I'm wrong S3 users) S3's still use the style cover in your pic.
  8. timontour
    timontour Member
    37
    thanks they are different the guy sent me a pic.
    not sure about the s3 cover it looks very similar
  9. big harty
    big harty Member
    307
    15
    Don't bother. Fit a forge twin take and shut the bonnet and enjoy the noise. :p
  10. Minstadave
    Minstadave Member
    560
    19
    The S3 engine cover with the integrated air filter fits the standard 2.0T.
