A3 2.0t quattro info.
Heatho87 Jul 10, 2011
  1. Heatho87
    Heatho87 New Member
    9
    Hi this is my first post on the fourm, At the moment I have a bora 1.8t with amd stage 2 and in the next few months im looking to buy an a3 2.0t 2005- just what to get some info or any problems that they have I would like to get at least stage 1/2 .
    Any helpful info would be much appricated.
    Elliott
  2. Heatho87
    Heatho87 New Member
    9
    No one!
  3. audicruiser
    audicruiser Audi Heaven
    1,865
    Doesn't that tell you something lol.... I have had no trouble with mine. Not sure of any problems with them to be honest.
  4. Heatho87
    Heatho87 New Member
    9
    Have you had yours remaped
  5. leach76
    leach76 Member
    331
  6. Rhyso
    Rhyso Well-Known Member
    1,504
    311
    By the end of Saturday he will have haha
    As they are the same engine as the MK5 GTI then things to look out for are weak diverter valves, coilpacks and the PCV valve
    Otherwise they are an extremely robust engine
  7. audicruiser
    1,865
    Yes the drive back from Castle Combe should be an enjoyable one!! :yes:
  8. Heatho87
    Heatho87 New Member
    9
    Ok great so stage 1 are we looking at 240-260
  9. audicruiser
    1,865
    I have been quoted 240bhp and 280 ft/lb of torque.... That will do me I think!!
  10. Heatho87
    Heatho87 New Member
    9
    They must make alot more that that on stage 2 with a hi flow cat and exhaust 270+ my 1.8t bora is nearly 240
  11. Heatho87
    Heatho87 New Member
    9
    What turbo do they have is it a ko3s or ko4
  12. quattro81
    quattro81 All the gear.. No idea
    970
    90
    Ko3 mate.. Ko4 is on the S3
  13. Heatho87
    Heatho87 New Member
    9
    So just the same as the old
    1.8ts has the turbo been upgraded then from when it was on the 1.8ts because 240 bhp was the max you could go.
  14. audicruiser
    1,865
    Have you had the Bora rolling roaded at 240bhp?? Fair play if you have, but if you haven't then I expect you are around the 220bhp mark...
  15. Shane.
    Shane. Member
    486
    As above only problem I have had since mapping is the diverter valve which has now been replaced with a Forge alternative.
  16. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Had this engine in a Golf and had to replace the clutch/DMF after Stage 1 remap, DV was changed too just to be sure as its well documented that this is a weak component.
    Other than that, no issues, great engine.
    Enjoy.
    Paul
  17. Heatho87
    Heatho87 New Member
    9
    Thanks for the info guys
  18. mrpeng
    mrpeng 2.0T Quattro
    78
    quick thread jack save starting a new while we on topic thinking of remapping my 2.0t quattro whats with the dv thing will this need doing at the same time i saw the rev d 1 is that only for the s3 thanks
    Lee
  19. phil76
    phil76 Active Member
    572
    40
    The 'Dv' diverter valves were a massive weakness on a certain aged car until they revised them,they are just a rubber diagphram on the old ones that become brittle n rip with movement,they were pooh on standard cars and then when cars were mapped they just ripped them a new 'A-hole' to put it kindly,they are about £70+vat from the dealers
