A3 2.0 tdi - Radiator outlet sensor
stevieb Oct 17, 2012
  1. stevieb
    stevieb New Member
    12
    Engine managment light came on a few days ago i ran vcds and it came up with the error " coolant temp sensor radiator outlet g83 or 63" i changed the coolant temp sensor at the back of the engine 2 months back and need help finding this one now and any part numbers if anyone knows,thanks
  2. Boon
    Boon Active Member
    441
    59
    Mine has the same, also changed the sensor between the block & battery. No fix!
    Seems to be a common VAG sensor go... My mates S3 8L and another's VW Lupo both had the same sensor fault on VCDS
    All 3 run fine and dash temperature gauges work fine so not bothered me much!
