A3 2.0 TDI DSG - vibration when hitting 70mph and slight knocks... :-(
210_MIH Oct 9, 2012
  1. 210_MIH
    210_MIH Drive it like u stole it
    108
    Hi All
    Got another problem with my A3 2.0 TDI DSG.
    Was driving on the M60 at 70 with cruise control on. Felt a vibration from the front somewhere, so i disengaged CC and the vibration went. As soon as I put the accelerator down, I felt the vibration again, through the pedal...now I cant tell if it was a bad road surface or the car...
    Prognosis: dropped it in neutral at that speed to see if it was the bearing...nope as the sound went...recently, I've had the NSF CV gaitor changed and both fron wishbone bushes....to be honest the car hasnt been the same since I got this work done...
    Im also getting some knocking sound at the back somewhere...which I cant pinpoint...any ideas??
  2. andrecc
    andrecc Member
    253
    do you get knocking noise while braking or reversing mine is doing knocking noise but when i have someone look at it it doesnt make noise i wanted to.
    annoyyying! ?
  3. shariain
    shariain Well-Known Member
    1,182
    190
    I had something just like this recently. It turned out to be my inner cv joint on the passenger side when I was driving for a short period of time @70/80 it would come but come off the power it would go and driving at slow speeds it wasn't there.
    http://www.audi-sport.net/vb/showthread.php?t=169913
  4. 210_MIH
    108
    I took it to a VAG specialist who couldnt find the noise. I get the knocking at slow speeds and the vibration at higher speeds....hmmm what did you pay to have your inner CV joint done?
    Has anyone had wishbone bushes replaced before?
  5. shariain
    1,182
    190
    My total was £250 but that was getting other stuff done to. Would think just the inner cv would be about £180/200
  6. 210_MIH
    108
    YUP inner CV joint...couldnt seem to find this part on its own so ended up getting the whole drive shaft for that side....thanks shariain...I picked one up from the scrappys in the end...
    shariain likes this.
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    probably a wheel bearing
  8. shariain
    1,182
    190
    Glad you got it sorted dude.
