A3, 2.0 TDI badge positions on the boot lid?
A1DEYB Jun 29, 2009
  1. A1DEYB
    A1DEYB Well-Known Member
    1,681
    43
    Morning,
    Please can someone tell me the exact locations of the badges on the boot lid or how i can refit new badges after the old badges have been removed?
    How do you the dealers fit the badges, i assume they use some sort of template?
    Thanks:icon_thumright:
  2. Lee_R
    Lee_R Active Member
    2,499
    12
    THey look better without the badges, leave them off!
  3. A1DEYB
    1,681
    43
    They are off at the moment, i removed them.. Might put them back on, i don't know yet, trying to retain a standard look..
    :icon_thumright:
  4. heyadamhey
    heyadamhey Member VCDS Map User
    126
    here you go. pretty much inline with the bottom of the tail light...
  5. A1DEYB
    1,681
    43
    Thanks for that, do you know if you get some sort of template to fit them when you buy the badges?
  6. gixxer600k4
    gixxer600k4 Member
    692
    id say keep them off, its still looks standard with them off, you can request the car from new to be badge-less.
  7. mdre83
    mdre83 Member
    634
    Persoanlly I'd leave them off, however, if someone has access to Elswin you can view the template which contains the exact measurements of the badges. I don't have access to it at the mo but could send the details through tonight if no one replies in the meantime mate ;)
  8. A1DEYB
    1,681
    43
    Good man, if you could show us some sort of template when you get a minute that would be great, i don't know whether I'll put them back on yet, just mulling it over that's.. You could say I'm a bit bored and looking for something to do. :haha:
    :icon_thumright:
  9. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,473
    610
    OFF OFF OFF - in my opinion!
  10. a_sagad
    a_sagad Member
    119
    Is yours a quattro? And does it have a quattro badge? If so the badges look better with the Quattro badge!
  11. A1DEYB
    1,681
    43
    Mines not a quattro no, i know which bads you mean, i won't be putting a quattro badge on, but i have seen A3's with an S-line badge where the quattro badge sits, that looked pretty good.
    Thank
  12. inS4ne
    inS4ne lives for speed
    96
    Don't go putting an S-Line badge on there, you wouldn't get away with it ;)
  13. A1DEYB
    1,681
    43
    Yeah true, i'm an OEM all the way man, i'll leave the S-line badges where they should be the sides and the front grille!
    :icon_thumright:
  14. A1DEYB
    1,681
    43
    Any news on this template mate?
    Thanks :icon_thumright:
  15. Dines
    Dines Ex-Corrado G60 Nut
    Check with Audi; on most VAG cars, the letters come held in a clear plastic pack. It holds the letters in the exact postion needed - you simply remove the backing, press the holder to the car and then pull off the clear plastic pack.
    That way, all you need to do is mark the position on the car using masking tape along the bottom and one edge.
    You can see what I mean here http://www.awesome-gti.co.uk/product.php?xProd=3418&xSec=391
  16. mdre83
    mdre83 Member
    634
    There you go mate, hope this helps... appoligies for the delay. Tried to get on last night but forum was down ;)
    Front Wheel Drive...
    a = 15 mm
    b = 12 mm
    c = 115 mm
    Quattro...
    a = 15 mm
    b = 12 mm
    c = 4 mm
    d = 115 mm
  17. A1DEYB
    1,681
    43
    Good man that is just what i'm after, i'll save that!
    Thanks for your help. :icon_thumright:
  18. A1DEYB
    1,681
    43
    Thanks.
    :icon_thumright:
  19. mdre83
    mdre83 Member
    634
    Updated my previous post with Quattro dimensions too ;)
  20. A1DEYB
    1,681
    43
    Mines not a quattro so i won't be badging it as one fella, thanks anyway though. :salute:
  21. A1DEYB
    1,681
    43
    Where did you find this information if you don't mind me asking? Is this something i could get hold of?
  22. NHN
    29,523
    1,766
    Leave them off man as it looks better without, trust me.
  23. mdre83
    mdre83 Member
    634
    Info came from Elswin mate, software that the dealers use.
    If you do a quick search on flea bay you'll probably be able to pick it up for about a fiver.
    As for the badges mate, I'd leave them off. Makes the back end look a lot smoother ;)
  24. jd2
    jd2 New Member
    This is exactly the information I need! Would you be able to repost the photos please? (I'm assuming it's valid for a 2011 Audi A3 3dr?)
    Thanks,
    James
  25. jd2
    jd2 New Member
    Hi,
    I don't suppose you could repost the images if you still have them? This is exactly the information I need (assuming it is relevant for a 2011 3dr A3?).
    Thanks in advance for your help.
    James
