a3 2.0 tdi 2006 loss of power white smoke.
dallo Apr 27, 2013
  1. dallo
    dallo Member
    143
    could somebody give me some advice my 06 a3 2.0 tdi seem to give out white smoke some of the time takes ages to get up to temperature.when driving it seems to go a bit then lags then goes again.havent noticed it losing water.read on internet it could be egr cooler or egr valve or oil cooler anti judder valve or even the head gasket any help would be appreciated so I can narrow it down a bit thanks.
  2. Yiddogaz
    Yiddogaz Member
    31
    White smoke is normally water getting into the combustion chamber but someone with a bit more knowledge will be able to help you diagnose it properly.
    The loss of power makes me think turbo!
  3. dallo
    dallo Member
    143
    it goes ok just like theres a big flat spot
  4. TDI140
    TDI140 Well-Known Member
    1,632
    175
    My car threw out white smoke yesterday after turbo popped
  5. dallo
    dallo Member
    143
    how will I check turbo whats the symptoms?
  6. dallo
    dallo Member
    143
    Any more advice or some checks I can do before it goes to garage?
  7. TDI140
    1,632
    175
    Mine didnt even make the police siren noise it just went within second of changing the intake pipe boot that connects onto the turbo compressor housing as mine was knackered and as soon as i changed it for the new one my turbo blew up at 1500 revs just went bang
  8. TDI140
    1,632
    175
  9. dallo
    dallo Member
    143
    Checked all the hoses to and from the intercooler.
  10. TDI140
    1,632
    175
    What about the ones connected onto the actual turbo housing ? As the one in my picture is the boot that comes onto the turbo intake compressor housing
  11. dallo
    dallo Member
    143
    Where are these located?
    only checked the rubber hoses from the intercooler.
    now you mention it I have heard a a loud hissing sound when revving the engine.
  12. Double J
    Double J Member
    93
    15
    How did you know your pipe was knackered buddy?
  13. TDI140
    1,632
    175
    Had it boost leak checked and was pouring out with smoke right from that hose
  14. TDI140
    1,632
    175
    I knew it was knackered due to having a dump valve noise which was odd on a tdi and also boost gauge was dropping pressure when accelerating
  15. Double J
    Double J Member
    93
    15
    Thanks buddy. I think I've got a bit of that on mine so I'll check it out.
