a3 2.0 tdi 140 won't start
mat6413 Aug 25, 2011
  1. mat6413
    mat6413 New Member
    Please help, i have a 2005 audi a3 2.0 tdi sport 140bhp. I got in it this mnorning and it wouldn't start, it took about 5 min to get it to fire. I put vagcom lite on, it has come up with glow plug circuit fault. Once it has started its fine for the rest of the day. I have booked it in to get it repaired, just looking for any ideas ? thanks mat6413
  2. A1DEYB
    A1DEYB Well-Known Member
    1,682
    43
    Mine sounds similar, its a bastard to start in the morning also.
  3. mat6413
    mat6413 New Member
    the car sounds like a shed in the mornings, it has justed been serviced. I hope its a relay or something, not a ecu fault,
  4. A1DEYB
    1,682
    43
    So does mine, it's very lumpy on tick over also.
  5. Graham89
    Graham89 Derv Perv
    310
    Sounds like glow plug failure. Without glow plugs it will struggle to start unless its warm from driving earlier on.
  6. A1DEYB
    1,682
    43
    I thought glow plugs only work when the temperature was cold? A bit like a choke? Or am i totally wrong here?
  7. Lings
    Lings Active Member
    2,059
    31
    your totally wrong
  8. mike foster
    3,967
    So do you have any ideas to help ?
  9. A1DEYB
    1,682
    43
    Am i? Why's that then?
  10. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    just put new glow plugs in mine £40.00 delivered
  11. audigex
    audigex Active Member
    591
    45
    Glow plugs do the same job as spark plugs, but in a different way. Basically a current is run through a wire in the plug until it "glows" hot enough, and that is then used to ignite the fuel.
    If your car is struggling to start, ie doing that "coughing" noise as it attempts to fire but doesn't quite catch, then try turning the key to ignition, waiting until the glow plug light goes out and turning the key off, then repeating a couple of times... sometimes the problem is that the plugs aren't being heated up enough to ignite the fuel: several attempts to heat the plugs can help (which is also why they usually fire after a while, but it's less effective due to the fuel cooling the plug down each time you try and fail to properly turn the engine on)
    Also effective when your battery is going flat or glow plugs are wearing out - not effective in petrol engines or if there's a problem with fuel/air going into the engine.
    A1DEYB and tdi-man like this.
  12. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    first thing i would do is get some new glow plugs in there mate they are cheap to replace and if they are failing then the car will be a right pain to start
  13. A1DEYB
    1,682
    43
    Ahhh i see, makes sense now! Thanks :salute:
  14. Lewis583
    956
    91
    Also while the top is off i'd check the injector loom for oil ingress
