A3 2.0 TDI 140, turbo/boosting problems
Dom29 Jul 20, 2013
  1. Dom29
    Dom29 Member
    61
    9
    hey all
    My a3 is very strange sometimes itll have loads of power other times it wont, the turbo does hiss quite a lot but heard that was common with these models?
    Anyway, say i have a car full and am going up a hill the turbo will really stuggle and on rare occasions it will cut out all together until i turn off the car completely and start it up again.
    Ive tried to see if it makes a difference when the engine is warm but it appears to be random.
    Any ideas ? thanks
  2. NHN
    29,601
    1,782
    The turbo's internal parts are getting stuck & causing overboost issues & thus gives you limp mode, so if this turns out to be the case, more than likely is, then 2 options, remove & clean or swap out for new.
    Depending where you are, we could do this for you.
    Also got a brand new turbo sitting in a box to sell.
  3. Dom29
    Dom29 Member
    61
    9
    How much are we looking at for the turbo?
  4. NHN
    29,601
    1,782
    I'll PM price for ours.
    Beware of cheap units refurbed with Chinese inferior internals, that simply are not up to the task of the boost levels.
  5. Dom29
    Dom29 Member
    61
    9
  6. NHN
    29,601
    1,782
    Forget it, its a temp solution that doesn't work very well tbh, only way to guarantee good results is to remove, strip, clean & refit or fit a new one.
    I've done number of these & the grime I've cleaned of them internally, would no way come of with this stuff.
  7. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    As NHN said, how many miles have you done? Has the turbo been changed before in its history? Might be worth a new or recon on instead of a clean?
  8. Dom29
    Dom29 Member
    61
    9
    the car has done 106k , i got it on 103k so dont know to much about the history!
