A3 2.0 Tdi 140 BKD - vibration on idle
RyanB88 Oct 1, 2013
  1. RyanB88
    RyanB88 Member
    Evening all,
    Car = 2004 A3, 2.0 Tdi 140, DSG (BKD engine) on around 91k miles
    The car runs very smooth and produces good power from tickover to around 4k. The problem I have is when the engine is warm (anything above 70degrees approx) but especially when the engine has been running for a long time (20 mins plus) when the car is put into either neutral or park, there wil be a strong vibation/juddering on idle. It is so strong that even passengers have commented on it. This does not happen when the engine is cold and also stops IMMEDIATELY as soon as the car is put into Drive or Reverse. No funny noises and seems to drive fine upto speeds of well in excess of 100mph with no other issues. (I travel to Germany every few months)
    Any ideas?
  2. tinostp
    tinostp New Member
    15
    maybe some of engine mount is in the bad condition, and needs a change.
  3. J8TT X
    J8TT X Member
    360
    9
    Engine Mount, Gearbox mount, Flywheel should all be checked
  4. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Mine was same symptoms as yours and it was the DMF in its early stages of going. Is there a noise to go with the shaking?
  5. NHN
    29,568
    1,779
    Yeap as above, mounts would be my 1st choice, 04 car doubt they've ever been changed.
  6. OhSoFresh
    OhSoFresh Member
    95
    Same problem, looked at work today and seems to be gearbox mount... not sure if I can replaces the bush or I'll have to replace the whole frame yet, as it looks that way. anyone replaced one?
  7. Charlietdi
    Charlietdi New Member
    I had this exact problem on my Audi A3 2.0tdi BKD 55plate , wobble at idle once at 90, After a few months of playing about with replacing injectors , loom , timing torsional adjustment, I finally bit the bullet and sent it to my local indy, they sorted it the same day and at a relatively minor cost from what I had spent so far ..... Lesson learnt it think I would recommend these guys if your having running issues V.A.G. Technik in Eccles Manchester.
  8. SnazzyWafles
    SnazzyWafles Active Member Team Panther Audi A3 TDi
    206
    34
    What ended up being the issue?
  9. Charlietdi
    Invoice states software adaption after checking torsion value of timing which I had already done but they needed to check it first , lad who works there said many reasons this happens but on this occasion it was that .
  10. SnazzyWafles
    206
    34
    Probably raised the idle rpm to 900, that tends to do it :happy:
  11. Keram
    Keram Active Member
    242
    41
    Or lowered as I did to myself which also helped :)
    tdi-man and SnazzyWafles like this.
  12. slizza786
    slizza786 Active Member VCDS Map User
    399
    27
    same issue with mine, need to have an inspect on the engine mount. Thanks for the advice.
  13. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    lower idle will help
    change all mounts as well I have donr mine and a lot better
  14. Part-Timer
    Part-Timer Member
    My mechanic just eliminated limp mode stripping and cleaning turbo thoroughly, fitted some coilovers & eliminated squeaky suspension, fitted new rear brake caliper, a new turbo-back exhaust and did something to driveshaft, replacing CV joints I think.
    Now new problem is similar, but when coming to a stop say for example at the traffic lights, there will be a strong vibration / juddering coming from behind the centre console in dashboard when in gear / drive / sport (DSG). Also stops IMMEDIATELY as soon as the car is put into park or neutral or with a little rev. I'm able to feel it on the brake coming to the stop and being able to make it louder / quieter using brake under a couple of mph.
    Mechanic seems to think they may be some trapped air in brake caliper, or something to do with ABS.
    I don't think it or feel it.. Brakes feel v.good, car runs v.good. After one day it still sometimes does it, sometimes it doesn't but seems to be even louder and happening more , and when starting the car ( it starts fine) then putting into drive I get the loud vibration / juddering. When pulling away slowly I can feel it on accelerator pedal.
    Could anyone please note what sounds like the culprit, if it could be Engine Mount, Gearbox mount, or Flywheel etc so I could get it checked and fitted or is it same scenario and all three need checking?
    2004 2.0 TDI BKD A3 , FLYWHEEL REPLACED AROUND 30K AGO
