a3 1.8t noisy/loud on start up.
wossy57 May 23, 2011
  1. wossy57
    wossy57 New Member
    hi basically i was just wondering if the above is normal?
    cheers
    ross
  2. quattro1
    quattro1 Member
    639
    try and explain what noise it makes mate as it could be a few things
  3. wossy57
    wossy57 New Member
    it just sounded like a diesel i guess, for about 5 seconds then was quiet as anything. i dont really know how else to describe it?
  4. quattro1
    quattro1 Member
    639
    does it do it every time? only from cold? or when hot aswell? any idea if its coming from the top end of the engine or one of the ancillary parts?? like i said it could be a few different things lol :)
  5. wossy57
    wossy57 New Member
    i have never really tried starting it when its hot, it sounds abit like its coming from the top of the engine, do you know of anything common that would cause it to be noisy for such a short period?
  6. quattro1
    quattro1 Member
    639
    well you might have a sticky lifter or might not be getting good oil pressure into the head on startup, but i wouldnt want to give a definate answer because ive never really heard of these suffering from that, im sure someone will be able to give you more help
  7. wossy57
    wossy57 New Member
    cheers, it has only done it a couple of times from cold, and other than that its fine. thanks again.
  8. quattro1
    quattro1 Member
    639
    i wouldnt worry too much about it, aslong as it stops sharpish and the engine runs fine/ pulls nice in all the gears it cant be anything too drastic! might be worth checking when the oil was last done and sticking some fresh in there if its been a while
  9. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Hi dude id say its your manifold thats got a slight fracture. That or your pick up pipe and the bottom ends gone but you would definitley know about that and it wouldnt be goin away lol.also engine code would come up .
  10. quattro1
    quattro1 Member
    639
    could be the manifold-turbo or turbo-downpipe gasket is on its way out aswell, had that with my old 1.8t, would blow on start up until it warmed up and expanded
  11. wossy57
    wossy57 New Member
    thanks guys i will give it a check over!
  12. quattro1
    quattro1 Member
    639
    just get a mate to start it up from cold and put ur head right at the back of the engine bay as close to the turbo/ehxuast as possible and have a listen. has to be from cold though
  13. wossy57
    wossy57 New Member
    appreciate your help mate, il update with what i find.
  14. ayfreetee
    ayfreetee Well-Known Member
    1,442
    276
    Make sure you have the correct oil in there 5w 40 and a new oil filter, it might be worth taking the sump off and checking the oil pickup isn't blocked, making it hard for the oil to get up to pressure.
  15. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    if your talking about the pre warm up mine does this quiet loud as its ideal is at 1.5k for a few seconds then you will hear a whistle this is when the pressure has been released and will return to 780-800revs mine does this all the time from cold once warmed up it will just kick over every time without this noise.
  16. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    1.8Ts are very tractorish on startups
  17. wossy57
    wossy57 New Member
    See i thought it sounded like a pre-warm up phase but as i dont have much knowledge about audis i thought the worst.
  18. Gavin G
    Gavin G Member Audi A4 S-line owners group TDi saloon
    171
    22
    Exactly the same as mine
  19. ayfreetee
    1,442
    276
    the wistle noise you are hearing is the air pump running, its an electric almost turbo type pump that pumps fresh air into the intake system to help emmisions when the engine is cold.
  20. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    my gf has an 09 beetle 1.6 which sounds as if it has the same starter noise as my 1.8t. Are they all the same?
  21. aragorn
    17,884
    688
    It could be the non-return valve in the back oil filter housing. They can sometimes wind out, which will cause the engine to rattle like it has no oil in it for a few seconds at startup then will go quiet as the oil gets pumped round.
  22. buznout
    buznout New Member
    I have just joined to try to track this one down.
    My 8L 1.8T has started to rattle around the accessory end of the engine during cold startups. It doesn't happen every startup but the frequency is increasing. Recently serviced and extremely low k's/miles, it sounds like it is coming from a belt tensioner or something in the front.
    I wonder if this is the same noise?
