A3 1.8t AGU engine ... car turns over but will not start. HELP
S3 Paul Oct 22, 2010
  1. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,821
    105
    A mate of mine has the above car.
    One morning it just refused to start so i plugged in VAGCOM but there are no faults stored.
    It turns over but doesnt even sound like its trying to fire, After a few seconds of trying there is a wiff of petrol ...
    Any ideas??
    Ive tried jump starting the car incase the batery was low but no change.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Immobiliser?
  3. bengal
    bengal Member
    537
    Could be the fuel pump relay does the fuel pump prime when the ignition is turned on? If it doesnt then its probably the relay. Then again it sounds like the fuel is getting through if you can smell it so maybe as mentioned above the immobiliser.
  4. Mrharris2
    Mrharris2 Boost needed
    666
    77
    Sorry to bring this up did you find the problem? I'm having the same issue and no codes to go by... Cheers
  5. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    Crank sensors my guess
    Mrharris2 likes this.
  6. Prawn
    11,354
    3,190
    I'd guess crank sensor.
  7. Mrharris2
    666
    77
  8. wigandill
    wigandill Member
    176
    maybe ignition amp
