A3 1.8t AGU Downpipe Fitting Woes
WorkInProgress Nov 6, 2012
  1. WorkInProgress
    WorkInProgress Member
    253
    Evening all,
    Had an unsuccessful morning trying to fit my new decat downpipe, I've only got ramps so couldn't get enough purchase on the bolts.
    I've got a mobile mechanic coming to look at it, he has a 1.8t Golf and advises me that sometimes the studs can shear/snap meaning a turbo out job to sort this. What's the likelihood of that happening? I did hope this would be an easy job for me to do but I've fallen at the first hurdle!
    Rob
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Get the gas on the nuts and undo them while they are nice and hot, they will never snap off doing it this way mate, or anther way is start the engine and run it up as that will help aswell to undo them
    JudderMan likes this.
  3. WorkInProgress
    253
    Cheers, will let it run for a while to heat them up then, fingers crossed I don't have any problems
  4. Prawn
    11,354
    3,191
    access from drive on ramps shouldnt be a problem either, I've always done them on my drive and never struggled too much.
    Running the engine to warm them can help, but it'll also make the downpipe red hot and make it much more tricky to get to it without burning yourself!
  5. WorkInProgress
    253
    Cheers Prawn, I'm going to see how this mechanic guy gets on, I've got so much to do on this car I'd rather just let someone else do it and I can get cracking on the rest of the stuff. Never buying a car on EBay again without viewing it first!
  6. WorkInProgress
    253
    Got the downpipe off this morning :cool:
    Does anyone know the diameter of the standard exhaust, think I'm going to need a reducer pipe as the downpipe is 2.5"?
  7. WorkInProgress
    253
    Found the info using the search function :readit:
    2.25" apparently....off to find a reducer
  8. 1982robw
    1982robw New Member
    i shall be removing a downpipe on an agu soon, how did you get them undone in the end? hopefully no broken studs?
    cheers, rob.
  9. WorkInProgress
    253
    I'd soaked everything with PlusGas the day before and my flexi had broken away so access to the bolts on the turbo was good. With the car on the ramps on the driveway it was awkward but ok. Hardest bit was getting the sleeve off the exhaust section which still isn't quite done.
    No broken or snapped studs though!
  10. 1982robw
    1982robw New Member
    excellent, did you need heat or did they undo cold with just the oil soaked on them?
  11. WorkInProgress
    253
    Mine didn't but a few people have suggested this...I think it could have been the liberal soaking with PlusGas or I might just have been lucky.
  12. Prawn
    11,354
    3,191
    hello matey, just read your PM.
    Stock exhaust is indeed 2.25'', 57mm.
    The decat should reduce to 57m also and the stock exhaust slide over it though.
    What size is the end of your decat?
  13. WorkInProgress
    253
    It's a 2.5" Toyosports/EBay job, I'll need to double check the size of the pipe where it meets the existing exhaust, I've maybe just assumed it's 2.5" all the way. You reckon it tapers to 2.25"?
  14. Prawn
    11,354
    3,191
    I'd check it all out first mate. Most decats reduce from 3-2.5-2.25 to mate to the stock system.
  15. WorkInProgress
    253
    This one is 2.5" all the way, will get a reducer pipe made up and finish fitting this week
  16. JudderMan
    JudderMan Well-Known Member
    1,003
    164
  17. WorkInProgress
    253
    Sorry for the delay in replying! That looks similar to mine, except mine has no cat. Good fit, relatively easy to do. I got a 2.5" one but I think the general consensus would be to go for a 3" for future proofing if you were to go for a K03s at some point
  18. JudderMan
    1,003
    164
    Ahhh, I have an AUM with a K03S anyway, so you'd recommend 3" then for my application? I'm only going stage 2 and no more* btw.
    *famous last words.
  19. WorkInProgress
    253
    I'm not 100% sure, best asking on here first before making a purchase! I think 3" would be best but I'm sure someone on here could confirm this for you
  20. Prawn
    11,354
    3,191
    3'' downpipe for ko3S please lads :)
    joesurf and WorkInProgress like this.
  21. JudderMan
    1,003
    164
    Prawn to the rescue once again :) Thanks pal.
    Right then, Relentless V3 seems to be the order of the day I do believe - I'll check prices as I'm not sure what they go for. I've had quotes for a Milltek £369 for a cat back or £300 from Powerflow but I want a resonator which the Powerful doesn't have so it might bump the price up. After that, it's mapping time :)
  22. ecudude
    ecudude New Member
    17
    Hope its ok to restart this tread. I am currenly looking at a smilar item on eBay for my A3 1.8T 1999 AGU:
    SEAT LEON 1.8T 20v STAINLESS STEEL 200 CPI SPORTS CAT PIPE EXHAUST DOWNPIPE | eBay
    The seller said it will not fit my AGU only AUM and AUQ coded engines (I guess these engine are from the facelift from 2000-).
    After searching the web, I cant find any post on this subject, that there is in fact a difference....
    Are the seller correct on claming it will not fit AGU engines?
    Please advise, since my original down pipe cat assy is struggeling with leaks and old age ;-)
  23. WorkInProgress
    253
    This should fit fine so long as yours is a FWD i.e. not a Quattro
  24. ecudude
    ecudude New Member
    17
    Yes mine is a FWD. After more searching the net, it seems that all FWD golf MK4's and A3 8L, have the same front pipe with cat.
    The eBay front end pipe have different titles/description but seems to have the same picture for all:
    Skoda:
    SKODA OCTAVIA 1.8T 20v STAINLESS STEEL 200 CPI SPORTS CAT PIPE EXHAUST DOWNPIPE | eBay
    Golf/Bora:
    VW GOLF BORA 1.8T 20v STAINLESS STEEL 200 CPI SPORTS CAT PIPE EXHAUST DOWNPIPE | eBay
    Seat Leon:
    SEAT LEON 1.8T 20v STAINLESS STEEL 200 CPI SPORTS DE CAT EXHAUST DOWNPIE | eBay
    any objections ;-) or those this seem resonable.... that they all will fit.
  25. Prawn
    11,354
    3,191
    AGU/AUM downpipes are all the same, AGU only uses one lamda hole, but they come with plugs anyway.
    It'll fit yours fine mate.
  26. ecudude
    ecudude New Member
    17
    Yeah, the second lamda should be easely plugged (maybe that's way the seller states AUM and AUQ only???!!)
    Thanks for the swift replay, workinprogress and prawn.
    I will but in some bids, and replay with some pic of the goodies, when it arrives :)
  27. ecudude
    ecudude New Member
    17
    PS would it get much louder with this down pipe cat, on an original existing cat back system(trough a downpipe of course :)
    Could the material stainless steel be rather thin.... making "thin can" sound from the system after fit?
    Anyone now the difference between say a miltek or jetex downpipe cat, in compare(except prise)?
    Just curious :blink:
  28. ecudude
    ecudude New Member
    17
    Well thats a blow out... my bidding item was removed in the hours of the last day:
    my bid was @41pound.... :nunu:
    well back to square1..
  29. ecudude
    ecudude New Member
    17
    I finally got a bid at 124£. I promised som pic's, here you go:
    compared with the stock;
    Installed:
    But I got an major issue. There is not enough clearance to the crossmember, so there is a banking sound at startup and when giving some throttle:
    What to do?
  30. ecudude
    ecudude New Member
    17
  31. ecudude
    ecudude New Member
    17
  32. ecudude
    ecudude New Member
    17
    You can see here that the original down pipe have a "bend or turn" around the crossmember:
    Just checked the LH transmission mount, and it have only a slight tilt to left(to the rear of the car):
    Seems rather tight, with normal wear and tear....
    I wonder if it will help to install the Vibra tech engine mounts "Road" version:
    Left Hand Engine Mount Mt 18 V6 - Vibra-Technics Compliance Technology
    Or is this waiste of mony for daily road drive only, and possibly more noice in the compartment?
  33. ecudude
    ecudude New Member
    17
    Found this kit of spacers to raise the engine:
    Mk4 Motor Mount Spacer Kit | Euro Image Tuning
    This I think would make enough clearance for my down pipe. They are currently sold out on 5∕8", so maybe go for 1"?
    I put LH engine mount in a wise, and managed to tilt i over, to a more level position. Further I have treated my LH mount with a sealant, and now waiting for it to try out. There was a lot of space to fill up with sealant:sign_omg:
