A3 1.8t 17705 fault code HELP
@unger Nov 9, 2011
  1. @unger
    @unger New Member
    15
    Hi everyone i have a 2001 A3 1.8t with a few fault codes ( I have VagCom ) the main one which is ****ing me off is the pressure drop between turbo and throttle valve CHECK DV !!!! I have checked all visible pipes checked the N249 pipes under mani when i changed crappy plastic dipstick! Only thing i can now think of is my DV leaking maybe or boost gauge pipes split ???
    Other Faults are 02 sensor which i replaced last year ?? And cooling system failure ??? Thermostat ??? Not the coolant temp sender replaced that last month !!!
    Any suggestions would be ideal.
  2. DenCar
    DenCar Member
    404
    Probably not much use to you but, my wifes car has had this fault code since she bought the car some 18 months ago. its a boost/vac leak but we just cant find it. Her car runs great and as good as my car that has no such error code, so we are not to bothered about it.
    DC
  3. @unger
    @unger New Member
    15
    Same here really car goes like a nut 80% of the time got a N75 problem too i think one minute itll be at 18 psi then for no reason wont go over 4psi pretty certain its N75 ! But this 17705 code is gettin to me LOL Thanks for your comment like you say its nothin bad enough to affect cars performance just must be a very slight leak in PCV sumwhere ! ! 1
  4. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Do away with the PCV system, there is a how to in the FAQ's.
  5. @unger
    @unger New Member
    15
    Yeah i have thought that mate will have to look at it fair few pipes to sort out but would make things alot easier! Had a bit of spluttering early like it was running out of fuel then went fine again ?? Had quarter of a tank in it too !!! Any ideas ? Iv been suspecting MAF for a while !!!
  6. macpdm
    macpdm Member
    403
    Sorry didnt see this thread but I also have had this issue.Sandip came down to help and firstly we found a kink in a vac pipe which may have contributed to the issues I was having which sound very similar to yours. We then cleaned the throttle body and swopped the DV for a miltek DV which sandip carries as a spare and went for a test drive. The car drove brilliantly so I bought a new OEM 710N DV and the car has been fine since, touch wood.
  7. macpdm
    macpdm Member
    403
  8. @unger
    @unger New Member
    15
    Thanks mate im gunna change every hose to silicone i rekon cant go wrong then! LOL
  9. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
