a3 1.8 turbo cold engine start loud screech
munkyman Apr 20, 2009
  1. munkyman
    munkyman New Member
    Hi guys,
    I just bought myself an A3 1.8 turbo sport on the weekend and noticed yesterday that on the cold engine start there was a rather loud screeching/squeaking sound coming from the engine. I tried it again this morning and the same thing. The annoying noise only lasts about a minute but it is very loud and sounds like an aircraft. It's hard to explain so I created a video of the sound. After a minute the sound goes away and is then followed by a strange whistle noise :whistle2: (you'll hear it in the video).
    Does anyone know what this could be?
    The cars done 91k miles and hasn't had the turbo changed.
    I've read the other posts on the forum regarding similar noises and I tried the common fixes including turning off the climate control and then starting but I'm still getting the same noise.
    Just a bit worried that's all and won't get a chance to take it to a garage until the weekend. In the meantime don't want to drive it could be something big like the turbo :unsure:
    Thanks in advance.
    http://www.youtube.com/watch?v=sb7xptDYus0
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
  3. munkyman
    munkyman New Member
    Hi. I turned the climate control off and still the same noise. I listened to the sound coming from the link you sent and it doesn't sound like that and last about a minute.
  4. abdus
    1,827
    Ah, is it the secondary air pump then...
    Sorry, I didn't actually read your post fully...lol
  5. abdus
    1,827
  6. JayMc
    JayMc Searching for 6th gear
    52
    9
    As said above. Its the secondary air pump. Make sure you check the plastic pipes to and from the pump. They become brittle and split easily which can cause the noise.
  7. munkyman
    munkyman New Member
    That's brilliant, that looks to be the problem. I'll have a go at that on the weekend.
    Do you know where abouts it is in the engine bay as that post was for vw golf?
    Thanks again.
  8. JayMc
    52
    9
    Its mounted right next to the oil filter, front of the engine down by the sump. Same as on the Golf.
  9. munkyman
    munkyman New Member
    OK great. Thanks again everyone.
    Will let you know if it solves the problem.
  10. abdus
    1,827
    as above, it the same as the Golf MK4. The A3 8L and Golf MK4 have a lot in common
  11. Adam-h
    Adam-h New Member
    Hi everyone,
    I have an Audi A3 1.9 tdie sportback diesel and it has 160k on the clock and only makes screeching noises when I accelerate. Does anyone know what the cause of the problem is. Please could you reply as soon as possible.
  12. Mark Greenall
    Mark Greenall Member
    171
    15
    When I had bought my a3 1.8t, mine did this noise. I took It to a local garage and he told me not to drive it as the hydraulic tensioner had collapsed on the timing belt and the screech was this cutting the timing belt. Sure enough we pulled the cover off and the bearing had cut a groove into the belt.
