A3 1.8 non-turbo - Fuel guage sensor/sender
DALE_AVANT Aug 18, 2012
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    630
    21
    Hi all.
    Our A3's fuel guage is all over the place at the moment, so I'm going to clean/replace it.
    Having done a search, I have found that it is located under the rear seats, but which side is it (there are two round items), and which sensor is the guage sender?
    Many thanks
  2. DALE_AVANT
    630
    21
    Anyone know this?
    :sm4:
  3. <tuffty/>
    21,697
    4,124
    Drivers side one and the fuel sender is integrated to the fuel pump unit... not sure if its available as a seperate unit... buy one from a dealer though as after market parts don't seem to fit or work properly..
  4. DALE_AVANT
    630
    21
    Sounds like a bit of a mish.
    Anyone got pics of the part I need to remove?
  5. DALE_AVANT
    630
    21
    Anyone happen to have a picture of what I need to remove?
  6. <tuffty/>
    21,697
    4,124
    A bit like these...
  7. DALE_AVANT
    630
    21
    Cheers Tuffty.
    If that's the fuel pump, where on that is the sender?
  8. <tuffty/>
    21,697
    4,124
    The floaty bit on the side :)
  9. DALE_AVANT
    630
    21
    Haha cool, cheers.
    So I would need to remove the fuel pump to get to the sender to clean I assume?
    We put £20 in yesterday and it said the tank was full - WINNER :haha:
  10. <tuffty/>
    21,697
    4,124
    In my experience cleaning won't fix it... its a carbon track that wears out so replacement is the only option... I changed the one on my A4 once... was about 30 quid from a dealer...
  11. DALE_AVANT
    630
    21
    Cheers.
    is the pump unit easy enough to remove?
  12. <tuffty/>
    21,697
    4,124
    Fairly... search through Westy's build thread as he has done a pump swap on his S3... will be similar to what you need to do
  13. DALE_AVANT
    630
    21
    In case anyone else is reading this, I have taken the below from W3STY's progress thread (many thanks):
    Back seats out and service panel off:
    Fuel clips and electrical clip off:
    Top of pump off:
    Whole pump out. Staring into half a tank of V power [​IMG]
    Was starting to get a headache from the petrol fumes at this point but cracked on.
    Lovely new clean pump:
    Bottom part in:
    All done:
  14. DALE_AVANT
    630
    21
    What's the best way to remove the two fuel lines at the top of the unit?
  15. DALE_AVANT
    630
    21
    In answer to this, there is a small concealed clip at the "front" of the fuel line where it meets up to the pump, push this in and twist gently, off it pops.
  16. cjsuk
    cjsuk Active Member
    567
    80
    Looks exactly the same as my pump and sendor on my old focus, i mean exactly the same wow lol anyway if it is, it's pretty easy, just like mentioned tho the fumes will be overpowering leave doors open and if you smoke, dont! (like i did, then realised and slowley removed myself from the car, those were the days).
  17. DALE_AVANT
    630
    21
    Can I replace just the sender itself, leaving the original fuel pump?
  18. DALE_AVANT
    630
    21
    Took the fuel pump out today and replaced the sender with a new part.
    Question.......should the float sit on the drivers side of the pump or the passenger side??
  19. DALE_AVANT
    630
    21
    Does anyone know the answer to this?
