a3 1.6 sport firing on only 2 cylinders
badladjohn Feb 27, 2012
  1. badladjohn
    badladjohn New Member
    hi guys, got a 2000 plate sport, the car is firing on 2 cylinders only, i got a new coil pack and tried that,exactly the same.i have clipped an inductive timing light to each of the ht leads and there is nothing coming out of the coil .just wondering if there are any common faults that i should be looking for? i am presuming either a wiring problem or a faulty ecu. no warning lights lit or flashing on the dash to indicate a problem. and ideas appreciated!
  2. badladjohn
    just traced all 4 wires back to the ecu plugs and tested with a continuity tester...all check out ok.does this mean an ecu fault ? or could anything else have an influence ,sensors ect?
  3. BENJAMIN
    BENJAMIN Active Member
    503
    93
    Check your camshaft angle sensor and wiring mate.
