A3 1.6 speedo out W plate.....
Tommo80 Apr 5, 2014
  1. Tommo80
    Tommo80 Member
    47
    The wife's speedo is way out on her A3,at 30 it reads near 40 at 70 it reads 90,what's the odds it's had box replaced with wrong box?
    Anything else likely to cause it?
    On a good note it passed mot today with jus rear bulb but only replaced that other month but it is dim compared to other side so not too bad.
  2. JimS3
    JimS3 Active Member
    736
    72
    Could also be the clocks have been changed or coded wrong, you can code them for 140, 160, 180 mph or km/h etc
  3. Tommo80
    Tommo80 Member
    47
    Cheers Jim might have to look into that but don't think it'll be cheap I had a fob programmed @ £90 lol think it might jus stay out for a while!
  4. JimS3
    JimS3 Active Member
    736
    72
    If it is the clocks, anyone with vag-com can sort it for you in a couple of minutes.
    There may be a member near you that can help for beer tokens.
  5. Tommo80
    Tommo80 Member
    47
    Like the sound of that,will look into it thanks :)
  6. moisty
    moisty Active Member
    212
    40
    I had the exact same problem with my v plate 1.6 a3. Other thing on mine was the full gauge always showed more . I tried all the earth leads as i read somewhere in was a possible cause but didn't help. I just learned to live with it .
  7. Tommo80
    Tommo80 Member
    47
    Yes as it stands she SHOULDN'T get a speeding ticket!!!! Lol
  8. moisty
    212
    40
    True i thought i had the fastest 1.6 car ever lol. Just watch the petrol gauge mine ran out as soon as it got a sniff of the red bar
  9. Tommo80
    Tommo80 Member
    47
    She goes through loads of juice in that being a carer she's doin 50 miles plus a day start stopping an gets jus over 300 to a tank,I tell her not to let light come on cause I cba cleaning the lines out if she sucks **** outta bottom of tank!
  10. moisty
    212
    40
    Should be easy to tell if your gauge is out . The warning light will come on well before it should . If i mind right mine came on about quarter of a tank on the gauge
  11. Tommo80
    Tommo80 Member
    47
    Bout halfway empty an qtr iirc,generally fill up at qtr jus in case!
  12. moisty
    212
    40
    Not sure but i think the cluster devolops a fault. There are lots of posts about tt's getting fixed because the clusters f' up and Audi admitted a fault so maybe related . I don't think vag.com or vcds can help as they can only correct by a few miles either way where as your gauges are out by a percentage ie faster you go the more they are out . Hope this makes sense and i could be totally wrong
  13. Tommo80
    Tommo80 Member
    47
    Yes deffo seems to be out by percentage rather than jus a few mph.
  14. moisty
    212
    40
    i had my 1.6 over 130mph on the clocks lol
