A3 1.6 Clutch Judder
Scotty_J Aug 25, 2008
  1. Scotty_J
    Scotty_J New Member
    22
    Good evening guys, new to the forum, and new to the Audi A3! i've just bought my first A3, a 53 plate 1.6 Sport with 53k on the clock.
    i've had a search on here, and google etc and it seems that S3's have a clutch judder problem, but what about my 1.6?
    In 1st and reverse, if you dont use a bit of acceleration, the car seems to judder. The gearchange etc is smooth and there is no slipping, do we reckon i may need a new clutch or is it common?
    Any help greatly appreciated, cheers
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    could also be the dual mass flywheel like the S3's. Its that that causes the problems as opposed to the clutch itself. Seems to be a problem for a lot of makes of car. If its not too bad I would wait till it gets worse as its NOT cheap.
  3. Scotty_J
    Scotty_J New Member
    22
    will mine have a dual mass flywheel? i've asked a mate whos a mechanic to price the job up for me and his supplier is 90% sure that my car doesnt have a dual mass flywheel going off the registration number? :uhm:
    kenlove likes this.
  4. Ash B
    Ash B Well-Known Member
    5,831
    84
    Have not noticed it in my a3 but i wont have mine back till friday so for the time been im driving a a4. when i get it i'll actually see if i can notice the problem you have :thumbsup:
  5. Scotty_J
    Scotty_J New Member
    22
    cheers mate that would be great! how does yours start as well? always first touch? mine didnt until i serviced it and now it seems fine.
  6. Ash B
    5,831
    84
    hi scotty j...Got the car back the car starts fine. I did as you asked i put the car in reverse didnt judder or any thing was smooth, but in first it did a bit but i was just using the clutch to move though.
    So i dont think its any thing to worry about. but is it a bigger judder or just slight little ones? You know before you had it serviced what was it like when you would start the car?
  7. Scotty_J
    Scotty_J New Member
    22
    thanks for getting back to me mate. mine is quite a big judder lol! with it apparently not having a dual mass flywheel in it i'm going to have a clutch put in it as its not going to cost much, see if that works! with the starting, sometimes it would kind of mis-fire on first touch then be fine.
  8. Ash B
    5,831
    84
    Its ok...lol hmm when you looking to have the clutch done? Probably would be best to get the clutch done first as it dont cost that much and could solve the problem
    Ahh my friends 1.9tdi a3 mis-fires quite alot its quite a new car but with loads of miles on it!
  9. Ash B
    5,831
    84
    Sorry bother you but what does your 1.6 sound like (exhaust)
    Seeing as i think mine has a hole, but audi like to say all 1.6 sound like it(didnt for the first 2-3weeks) cheers
  10. Scotty_J
    Scotty_J New Member
    22
    its pretty noisy being honest!
  11. Ash B
    5,831
    84
    ahh so maybe it is 1.6 lol
    Im still not to sure..
    How the car going? any photos of it?
  12. Ash B
    5,831
    84
    spoke to friend his a3 1.9tdi does the how judder thing! and its a big judder aswell not little...
  13. Scotty_J
    Scotty_J New Member
    22
    i'll take some pics when it stops raining lol!
  14. im_audi
    im_audi New Member
    Old thread but did you ever get this sorted? What was the fix?
    I've got a 1.6 FSI Sport Sportback (05) and got the exact same problem. I've had the clutch replaced but still have the same problem where it judders in 1st and reverse. Also, once the temperature reaches 90, I can feel a constant tap-tap-tap vibration through the clutch pedal, when lightly resting my foot on it.
    Will be taking it back to the garage next week.
  15. holderd
    holderd Member
    40
    I've got a 1.6 (BSE engine- non FSI) and the clutch is really poor. The gearbox went just over a year ago and the replacement clutch didn’t help in the slightest-so both the original factory clutch and whatever the garage fitted have been exactly the same.
    I notice it most when I'm pulling away sharpish and slipping the clutch. It works OK but I feel a slight judder through the pedal. Gear changes and everything else are OK :)
    As for the exhaust- they all sound the same. I've listened to a few recently and they all make exactly the same noise when you first start accelerating (I like it).
  16. Wil50nrs
    Wil50nrs Wil50nrs
    9
    Hi, I have just bought a 1.6 tdi sportback and I can feel a grating type vibration through the clutch pedal, anyone experienced this? Going to go for a clutch and flywheel but want make sure it's not anything else??
  17. TangoFiver
    TangoFiver New Member
    10
    Hi all,
    I found this thread in the FAQ's, but it doesn't seem as if there's an answer/solution?
    The reason i'm asking is because I've just bought a 2004 A3 1.6 FSI SE (6-speed) with 75k, and it seems to have the same symptoms as other members have posted - judder when setting off in 1st/reverse, but smooth in all other gears.
    From what i've read, it could be a number of things:
    Flywheel?
    Clutch?
    Normal?
    Did anyone resolve their issue? And if so, how?
    Thanks in advance,
    Joe :)
  18. TangoFiver
    10
    No definitive answer then? :(
  19. c_w
    c_w Well-Known Member
    1,163
    87
    It's clutch judder, why it's doing it I'm not sure though if the clutch is old generally they stay smooth right up to the end of their life. Assuming no noises from the dual mass flywheel, there may be some contamination on the clutch face. Judder will generally only affect setting off in 1st and reversing. Sometimes you can feel it going from 1st to 2nd, but once on the move it's not usually noticeable unless it's REALLY bad.
  20. Boon
    Boon Active Member
    441
    59
    Have you checked out the engine & gearbox mounts?
    Dogbone mount (lower gearbox mount in centre of car) is a favourite for wear and will also judder when moving off
  21. TangoFiver
    10
    Nope not checked the mounts - can this be done by somebody useless like myself, or is it a job for the mechanic while it's up on the ramp?
    If there were noises coming from the dual mass flywheel, what would this sound like? (I don't think it's making any abnormal noises!)
    Thank you!
  22. kenlove
    kenlove New Member
    interesting post. I am confused. Was told at Mr Clutch that judder is caused by flywheel, yet posts here are suggesting 1.6 BSE does not have a flywheel.
