A1 ABS controller help.
dandav1985 Aug 14, 2014
  1. dandav1985
    dandav1985 Active Member VCDS Map User
    360
    69
    Hello Lads,
    Scanned a forum members A1 the other day and for some reason all the byte tickboxes in the longcoding did not show any descriptions i was going to activate Hill hold but could not and it did not show the security code either when you hovered the cursor over the box.
    Can anyone help. Its a 14 plate A1. heres the scan off VCDS.
    Address 03: ABS Brakes (J104) Labels: None
    Part No SW: 6R0 907 379 BK HW: 6R0 907 379 BA
    Component: ESP9.0i front H03 0002
    Serial number: --------------
    Coding: 33DF488B232502C9CC1C1269C45A40951009
    Shop #: WSC 00046 412 00000
    ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
    ROD: EV_Brake1ESP90iBOSCH_AU21.rod
    VCID: 88197F493306095E537-80DD
    No fault code found.
    I did contact Rosstech but no joy as of yet.
    Cheers Dan
  2. dandav1985
    360
    69
    anyone............:confused:
  3. RobbieWebs
    RobbieWebs Well-Known Member VCDS Map User
    1,031
    249
    Are u sure the abs is the correct one for hill hold?
    Unsure for the A1 but for the A4 there are 1AT and 1AS. The first one is for hill hold and TPMS, the latter isn't compatible.
