A turbo for people that want a bolt-on solution-
R1GTI Mar 15, 2003
  1. R1GTI
    R1GTI New Member
    Ok - deed is done. I've got some pics of the install if anyone's interested?
    Bit of a newbie tho' so don't know how to upload in-line pics like above. Can anyone shed some light and I'll then post them.
    Thx. M
  2. Guest
    Greg
    I'll may you mine as well this evening. Im another webspace-less person :(
    will
  3. excursion
    excursion Member
    740
    The E05 K04 Hybrid
    K03 S Comp wheel & larger turbine wheel - looks like a k22 wheel to me:
    Learn more about it here
    This looks like the perfect bolt on to take you past the magic 300, sell your k04 to someone with a 180 or turbo sport and your well away /ubbthreads/images/graemlins/smile_smoking.gif
    I hope to see at least one of you with this and 320cc's before the summer is out /ubbthreads/images/graemlins/wink.gif
  4. s8n
    s8n Member
    207
    Research it carefully, ive followed this on Vortex and it produces no more power than a K04 from a TT/S3
  5. GolfTTish
    GolfTTish Member
    104
    Got one on the golf, and the turbos rated in the 250-260hp region at best. It's smaller than the K04 you've got on your s3's already.
    You'd be better getting a K04-23 modified if you want a bolt on option, or go for a propper big turbo.
    On an 150/180hp car this turbo works well as an upgrade.
  6. excursion
    excursion Member
    740
    This isnt for mine, I had a hybrid k04-23.
    From what I read the E05 was larger than the K04, they obvious mean the K04-15.
    Sorry guys!
  7. GoSPeeDxRaCeR
    GoSPeeDxRaCeR Member
    51
    sad but true...i was a hopeful..then i learned the truth
  8. Gambba
    Gambba Active Member
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    So what's your thoughts for someone with a fecked K03? What's the cheapest upgrade and the easiest to get a map for? Was originally considering a Mitsi TD04, but I'm concerened about the amount of work I'll have to do to fit it as the kit is intended for a 210/225 TT and whether I can get a map done cheaply...preferably Oettinger...any ideas welcome.
  9. dunk
    dunk Member
    770
    a modded k04/k03 hybrid is going to be a good replacement for a k03.
    for a real custom chip solution, i can think of several ways - someone like AMD, try revo they have some code for non-standard turbos, or maybe a dastek unichip - these dont actually change the ecu chip, but use a piggyback system to modify the chips responses.
    they are extremely good if the installer is good. the installation/mapping price is usually about £500
  10. GolfTTish
    GolfTTish Member
    104
    Just chuck a second hand k03S on it and run your standard map. You'll gain some top end for £250.
    Jabba have already produced some tweaked maps for k03s's on k03 cars (ndbw).
    Revo can offer maps for hybrids on dbw cars.
  11. excursion
    excursion Member
    740
    Agreed, no need to change your map, I ran a k04 on my std map whilst waiting for a remap.
    Obviously you're not going to get the most out of the turbo, but it's a cheap route to more power.
  12. GolfTTish
    GolfTTish Member
    104
    Should be no reason why it wouldn't run OK.
    I ran the e05 on a k03s map for months without a problem, but some guys have run ko3s on k03 maps, and had minor problems.
  13. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    Mine is still ok John ,waiting for f/p cat and fmic now before i pay revo another visit for a map tweak.Will i need larger injectors for safety's sake ,if so what part no's and cost? Cheers Andy
  14. GolfTTish
    GolfTTish Member
    104
    Don't know for sure andy. My glof ones were borderline on the ko3s at 4 bar, and bigger ones are £200+ the vat.
    Talk to Kev. He can give you a better idea.
  15. excursion
    excursion Member
    740
    I have a set of new Bosch 310cc's for sale. £175
  16. excursion
    excursion Member
    740
    injectors now sold.
