A small guide to doing basic cylinder head work ie porting/polish/gasflowed
Andrew@A.L.D May 27, 2010
  1. Andrew@A.L.D
    3,877
    617
    Yes i did
    @10in on .400 lift it made 155 cfm's on the inlet and 144 cfm on the exhaust
    Didn't go to .500 if i did it would of flowed more and the standard cams do lift that much anyway
  2. dany2k
    dany2k Member
    318
    impressive guide andrew, thanks for taking the time to write it up.
  3. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    hi andrew what mods would i need to to have this done mate so it runs perfect
    cheers
  4. harryc
    harryc Member
    34
    Looks good, do you know what the flow figures 'before' were or a % increase in flow?
  5. Andrew@A.L.D
    3,877
    617
    Sorry i did look what it did before, Someone gave me flow figures of a well know cylinder head man
    I did my work on the head and strapped it to the flowbench and beat his figures
    s3gazz you may need a tweak of the map.
  6. Andrew@A.L.D
    3,877
    617
    I think its about 20% more on the exhaust side and less for the inlet
  7. harryc
    harryc Member
    34
    Sorry for all the questions, did you get a chance to fit and test the head? never got round to dyno testing my head to see where the most gains (and or losses!) were. I could only judge by feel and increased top end performance. Id guess you would see quite healthy increases if the oem head is quite restrictive and boost picking up quicker.
  8. Andrew@A.L.D
    3,877
    617
    Well i fitted the head to my engine, ( spec in my sig ) its on a standard map and standard injectors i pushed it one day and i know i shouldn't, running 13 psi of boost it shows 273 bhp on the liquid, never done it again as i've going BT and needs mapping
  9. s3gazz
    1,376
    99
    soz again mate i dont make sence but what mods i need to got with the ported head
    cheers
  10. Andrew@A.L.D
    3,877
    617
    Send me the head and i'll do all the work on it
  11. StaceyS3
    StaceyS3 Well-Known Member
    2,491
    483
    Cant believe i haven't seen this thread before, looks like top quality work and as much as i'm pretty sure i could do mine (no where near as good as this) i think its something i'll leave to people that really know what they're doing ;)
  12. jamieA3
    jamieA3 Member
    150
    very interesting read. you obviously have a huge amount of knowledge and expertise. just want to say thanks for sharing it!
  13. Andrew@A.L.D
    3,877
    617
    Not been on this thread for some time now and noticed StaceyS3 reply
    StaceyS3 has one of my heads now.
    I've done some more work on head recently and having received a damaged ex JNL head that i've now cut up i've leant a lot more about the 20v head. Stacey's head is one of my new spec heads that i'm sure he will tell you about.
  14. Go write up although id probably pay an expert like the OP to do this for me !!
  15. Andrew@A.L.D
    3,877
    617
    Thats why i did it as i have seen to many people mess them up but also try to give good advice so they don't mess them up
  16. superkarl
    superkarl MAN OF STEEL
    9,427
    2,394
    What are the differences now andrew? Do you have pics to illustrate it?
    Ive not started on mine yet, the heads only been cleaned so far. Need to get a move on really
  17. Andrew@A.L.D
    3,877
    617
    Its something that can't really be show with illustrations, lots of measuring tools needed and you would need to be stood next to me for me to show you the different parts of the port thats been modified.
  18. Andrew@A.L.D
    3,877
    617
    Just redone my own head due to unfortunate cam breakage
  19. Dani_B19
    9,167
    363
    Cant believe thats the mess of a head i gave you mate haha, top work.
    Benjiman46 likes this.
  20. <tuffty/>
    21,008
    3,770
    Nice work dude...
  21. Andrew@A.L.D
    3,877
    617
    Just got to get it off to my mates to get the guides done
  22. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    I would love to do something like this one day... Not necessarily to the S3... This sort of thing fascinates me haha
  23. Andrew@A.L.D
    3,877
    617
    Thank you everyone
    I just hope it performs well when fitted as this is not the end and i do have more planned for her, this was just a set back to my plans.
  24. Andrew@A.L.D
    3,877
    617
    Just done a big valve head for a 20vT
    Will see what that does on the flowbench now, this will be put on are CNC mill for deck cooling modification
    dre_S3 likes this.
  25. <tuffty/>
    21,008
    3,770
    I need to re-read this again I think... I might look at doing my exhaust ports
  26. Andrew@A.L.D
    3,877
    617
    Get your manifold made up first with large ports and go from there but well worth it
    my manifold ports are the same size as the gasket so massive really, the hotside has also been ported
  27. mikem1
    mikem1 Golf with BAM Engine
    57
    Very interesting, email sent.
    Mike
  28. Andrew@A.L.D
    3,877
    617
    Got you mail
    will be looking into doing a small port head for someone that's want to see if a ported small port head will make a better drivable car rather than a his standard AGU head
    i can understand his thinking keeping air volosity high with a gtx3071 and a 10:1 compression . Very driveale if it all works out
  29. mikem1
    57
    Is that from the perspective of doing it on a 2WD car to see the driveability improvements as opposed to on a 4WD or purely on a small port head?
    Mike
  30. Andrew@A.L.D
    3,877
    617
  31. Andrew@A.L.D
    3,877
    617
  32. Andrew@A.L.D
    3,877
    617
    Finished another ST170 head
    BTW the 20v head in the background has been sold, Massive spec also but didn't take any pictures of thats
  33. N8
    17,163
    718
    Great work!
  34. Andrew@A.L.D
    3,877
    617
  35. Andrew@A.L.D
    3,877
    617
