a rattle sound on start up but only last a few seconds
harvey01 Jan 5, 2012
  1. harvey01
    harvey01 Member
    523
    9
    as above has anyone had this happen or is it cam chain rattle ?
  2. <tuffty/>
    21,874
    4,201
    Sounds like the cam chain tensioner...... rattles while pressure builds up
  3. harvey01
    harvey01 Member
    523
    9
    can i just change the tensior as its not long had the cambelt done
  4. <tuffty/>
    21,874
    4,201
    tbh its fairly normal.. if it rattles all the time is when it normally needs changing... I have rebuilt the majority of my engine including new oil pump and non return valve/oil filter housing .... mine still does it occasionally... normally when cold and it is cold out atm...
    Non VVT tensioners are around £100 but VVT ones are £350 odd...
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Its worth mentioning you can get hold of the plates/shoes now that the chain slides on and is more likely to wear for around £30
  6. <tuffty/>
    21,874
    4,201
    Replaced mine and still rattles first start when cold :)
  7. jack.s
    jack.s Member
    119
    Mine does this, i was told that it could be the starter moter on its way out.
  8. G60DAN
    G60DAN Member
    383
    Iv'e had a new OEM VVT fitted and it still makes the noise on start up so keep your money and spend it something you need.
  9. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Same here, I get the rattle as well.
  10. sportstractor
    sportstractor Chugger
    2,709
    same,
    your best off cranking your stereo up for those first few seconds :icon_thumright:
  11. scotty_24
    scotty_24 Well-Known Member
    1,052
    250
    I have this too when starting in a morning when it's freezing, my mates a VW tech and said don't worry unless it does it all the time, it's just the pressure building
  12. harvey01
    harvey01 Member
    523
    9
    ok thanks chaps o and chapses
