A rat in my engine bay?
MrTackalakalaka Apr 29, 2012
  1. Noooooo not a real rat......
    Started my car up today and pressed the AUTO button on the heater/fan
    Then it sounded like a small animal was being tortured in my engine bay. I then turned it off thinking what the bajeebus was that?
    Turned it on again and it made the squealing noise again. I then pressed the Aircon (snow flake) button and it stopped. I then started driving for a while and pressed the AC button again and it let out a shorter squeal. I tried it later on and it didn't do it again.
    Anyone know why it might be making that noise? better still......what?
    My AC (as far as i know) hasn't worked since I've had the car. I have never got round to re-gassing it
    cheers
  2. ant schof
    ant schof Member
    164
    Hi mate ,
    Had a very similar screeching / scraping noise from my S3 about twelve months ago , turned out to be the alternator
    clutch pulley breaking up , seemed to do it more when the air con was on . Also had the battery warning light flickering on occasionaly when this happened ! Worth looking at maybe . You could try slipping the multi v belt off and see if the noise goes away .
    Cheers Ant
  3. <tuffty/>
    21,899
    4,206
    Be one of the fans... mine does ther same occasionaly... its fine when the enginebay is warm but on cold start it can squeel a bit...
  4. Thanks guys!!
    I shall look into it! Will have a look in the engine bay and get the girlfriend to put the AC on. Sods law it won't happen until I'm next in the car haha
    Thanks again
  5. Dani_B19
    9,382
    403
    Mine does the same on start up up if i put aircon on.
  6. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    My old A3 made some nasty noises like that once, turned out it was the aircon clutch/pulley/compressor thingy whatsits failing and trying to escape from the engine bay.
    Liam
  7. fingermouse
    fingermouse thats me
    4,014
    117
    funny Ive just had a simular noise this morning, I was blaming the fact that ive lost my garage to the wifes new car so mine is now out on the drive getting wet :(
  8. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    had it on mine this morning too
  9. LoopTrooper
    LoopTrooper Member
    There is always the traditional turn the stereo up option?
  10. Prawn
    11,677
    3,677
    I was always lead to believe that this was a tiny bit of belt slip caused by condensation on the belt on a cold morning..... Both mine have done it when starting up with the aircon switched on.
  11. fingermouse
    4,014
    117
    mine sounded more like the fan in the car as if the bearings are getting a little dry
