A quick question
max69vk May 20, 2012
  1. max69vk
    max69vk Active Member
    862
    57
    Anyone know what this actuator & solenoid are for on the TDI? (located near to the cambelt) I thought they were used for engine shut down but they appear to do nothing on start up, turning off or running! there is vacuum going to the solenoid valve but nothing passing through it at any stage, if I apply vacuum to the outlet on the solenoid (that connects to the actuator) it doesn't hold any pressure. The itself actuator is tested & works & I've applied vacuum directly to it when the engine was running it appeared to make no difference to the running of the engine!
  2. Viking
    Viking Bloody Viking...
    226
    20
    What engine is it?
  3. max69vk
    862
    57
    PD170 BMN
  4. Viking
    226
    20
    Ah, I thought it didn't look familiar when compared to my BKD engine. It's not there on the BKD.
    What's the actuator connected to?
  5. max69vk
    862
    57
    I can't actually see as it connects to something behind the cambelt into the head.
  6. max69vk
    862
    57
    Right, looks like it could be the solenoid & actuator for the intake manifold. I've got no fault codes coming up for it & no idea how to test the solenoid valve, is it just a case of connecting 12v to it & seeing if it clicks?
