a problem with gearboxs
a3kid Jan 27, 2005
  1. a3kid
    a3kid Member
    122
    hey all just got my car back from dealers and whilst in there had a nosey in the workshop in there to my horror found out about a problem with early (MK1) A3s gearbox. (NOT QUATTRO)
    most boxes used were mk4 golf boxes used and the problem with these is that the crown pinion in the diff are not bolted on but riveted these can shear and punch holes through the bell housing which in all asspects kills the box and clutch and leaks all gear oil out. so all if you have a leak from gearbox (fairly major leak) this is proberly the reason why.
    P.S new box £1400 approx
  2. a3kid
    a3kid Member
    122
    well all the gear box refurbishers i spoke to say this is a common problem and is the main reasons for there work and exchange on the boxes
  3. HTC
    HTC Active Member
    3,428
    9
  4. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    Welcome to the world of VAG gearboxes. This has been a problem since year dot for VAG.
    There is a bolt kit available for them which solves the problem. God only knows why VAG don't fit the bolts at the factory and still insist on fitting rivets!!
    Here are pics of what happened to my Golf's gearbox last year :-(
    http://homepage.ntlworld.com/kevin.yeoman/DiffGoBoom001.jpg
    http://homepage.ntlworld.com/kevin.yeoman/DiffGoBoom002.jpg
    Mmmmmm, nice hole!!
    [/ QUOTE ]
    Not good /ubbthreads/images/graemlins/frown.gif
    I take it the bolt kit is an Audi fit job though?
  5. a3kid
    a3kid Member
    122
    no a good mechanic can do it but its an expensive job for little to be done catch 22
  6. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    [/ QUOTE ]
    I was just thinking get it done before it may be happens.
  7. a3kid
    a3kid Member
    122
    not sure if they sorted the problem for the 1.8t as think its a different box set up to the 1.6 can anyone confirm this
