A pillar trim removal
IANF67 Jan 13, 2014
  1. IANF67
    IANF67 Member
    Any tips on the removal. Need to route my microphone wire up and over. I'm assuming it will clip off but is there a good place to start the process
    cheers
  2. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,132
    you ll need to remove the grab handle above the driver to remove the a pillar trim itself
    2 screws which are behind 2 locking plastic tabs on the handle itself
    then lift the a pillar upwards and into the vehicle
  3. quattrojames
    14,050
    573
    Can you not just pull back the rubber seal and poke the wire under the trim that way?
  4. SL11CKK
    SL11CKK Active Member
    687
    35
    There is a screw under the cover that says Airbag and then remove the 2 screws holding the grab handle and also remove the sunvisor and then pull it off
  5. WolfAutoParts
    WolfAutoParts New Member
    The screws are going to be Torx 20 and / or Torx 25 size.
  6. IANF67
    IANF67 Member
    Thanks folks. Forgot to mention its a cabriolet
    Sorry
  7. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,319
    766
    Mr Wolf. If you want to advertise on here please contact the admin.
    Do not link to your business in your signature line, it has been removed.
  8. IANF67
    IANF67 Member
    Have done that quattrojames. Got to the top but need to get round to the front. Was planning on stickin the mic on the inside nesr the windscreen about 6/8 inches down the pillar
  9. Mollygoogle
    Mollygoogle Member
    227
    Don't run it up behind the rubber seal, run the cable to the back of the dash (access to the fuse panel for feeding it up/down) and tuck the cable behind the A pillar edge closest to the screen. Takes no more than 5 minutes without the need to remove the pillar
  10. Chrismawa
    Chrismawa Active Member
    457
    46
    Glad you asked this as this is exactly what I need to do! After removing the screws and pulling it off - theres no chance of the airbag going off is there??
  11. IANF67
    IANF67 Member
    After messing around for a while I've sited the microphone on the cluster it fits snug on the little ledge just under the PRNDS. Looks nice and sounds ok too from what people tell me anyway
