A pillar material?
jay1601 Jan 10, 2011
  1. jay1601
    jay1601 Well-Known Member
    1,347
    73
    starting my a pillar mini project soon.
    going to make a glass fibre pod for boost gauge. but i want to cover it in the same material as it comes in standard
    i think the roof lining is the same stuff aswel, but only got 2 scrappy near me and they gave me a stupid price for the roof liner
    where can i buy it from if any of you know
    thanks Jay
  2. coyle
    coyle From Show... to GO
    435
    its bloody hard to trim and make it look good due to all the curves. i just finished mine,
    heated it with a heat gun to shape it better to the A pillar.
    drilled holes through the pillar and pod, and countersunk the holes in the pod. then screwed through the two so the head sat in the pod below flush.
    but nylon lockers on the underside of the screws.
    then plastic filler over the screw tops, mask, primer, paint, job done.
    that way you dont have to fibre glass on to the pillar.
    thats just 1 option,
    i imagine if you got the pillar smoothed in to the pod realy well, and hit it professionaly trimmed it would look brilliant
  3. jay1601
    1,347
    73
    i'm making the pod mate, not buying a ebay pillar pod and making it fit
  4. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    i tried using headlining material and found it to be so hard to use as its not very flexible, if your doing a single pod may be do'able but still not easy so maybe best to try something different. i moulded mine using fiderglass then painted it piano black like my centre console looks the nuts muts to me
  5. jay1601
    1,347
    73
    i've look at yours before. very good work mate :)
    gunna take a look round the local material shop see what the nearest match is i can find to the standard stuff :)
    where did you get your head lining from ?
  6. s3_kev
    2,002
    23
    think it was through ebay if i remember correct, was £££'s though
  7. steve bain
    steve bain Member
    642
    try your local auto trimmers...may sell you an offcut cheap enough. thats what i have done in the past
