A nice package arrived...
Ross-A3 Aug 19, 2013
  1. Ross-A3
    Ross-A3 New Member
    Came home to these after work, 50mm H&R springs, now if someone could help me with 2 things...
    1) how do I remove the plastic thing above the front struts for them to be removed
    2) the rear axel seems like it's a 2 parter and my old fabia when replacing the springs only had 1 straight across axel, will there be a difference or is it just raise the car, remove bolts from the bottom of shocks then replace springs?
  2. stuartm
    stuartm VCDS Map User,
    260
    22
    On mine when I did the front coilovers, I just prized the plastic up enough to get the socket in without fully removing the plastic papanel and on the rear I just jacked the car up and unbolted the swing arm bolt with the help of a second jack. I found that to be the easiest way to get the rear springs out. No spring clamp needed on the back.
  3. H17YD L
    H17YD L Active Member
    383
    76
    +1 on all the above I did exactly the same!
  4. Dan_Mol
    Dan_Mol Member
    46
    Again same as above, and lots of swearing getting the back bolt on top mount (drivers side)
  5. Ross-A3
    Ross-A3 New Member
    Thanks for the help guys!! Hopefully get them on either Thursday or Friday then will update with some pics
  6. stuartm
    260
    22
    I agree with that, drivers side was a nightmare compared to passenger side. And plenty swearing lol
