A good non-messy tyre shine
Agent_Trig Apr 29, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    I'm currently using Chemical Guys Tyre Gel and although it gives a good finish, its far too messy to work with. The sponge gets saturated in the gel, which then turns black and cant be washed out.
    Are there any products which are easier and less messy to use? But at the same time, give a good long lasting black tyre shine?
  2. a9503128
    a9503128 Guest
  3. chiddles
    chiddles Member
    61
    meguiers do one which is purple its the nuts
  4. moag
    moag she's no d-turbo
    821
    35
    meguiars endurance tyre gel is my favourite. Lasts for weeks, the only problem with it is that it splatters black dots all over the side of your car when driving.
    Meguiars released the product in spray form this year and its also very good. Not quite as shiny as the gel but its quicker to apply and lasts well. It doesnt splatter the car either
  5. si hoc
    si hoc Member
    108
    i use cg gel with the megs applicator pad and no problems
  6. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Never had a problem with the megs gel splattering the side of the car, but I leave it for about 30mins before I drive the car to let it soak in.
  7. Sock
    Sock Shark in a Goldfishes clothing
    576
    I use the autoglym tyre stuff ( black label ) spray it on ten mins before I wash the car then just let it get washed off as I go along.
    Leaves a nice dark shine and does well at getting rid of any dirt etc
  8. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    I use blackfire stuff although it does come up with the same problem with the sponge. Quick question though do you clean your tyre walls as that helps with no only the black **** that accumilates on the sponge but also helps with the gel bonding on the tyre. Dont drive your car straight away after applying the gel or you can buff off the gel after applying to ive a more softer look.
  9. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i get the splatter even after i leave it. i think i put too much on. i just meguires endurance the gold class purple jobby. i do like a good shine though it does last a while too!
  10. Solly
    Solly My XBL GT - ii solly uk ii
    927
    I've always used auto gylm's bumper care (green sticker) one on my tires with the little washing up sponges u can get. last ages and gives a good shine one of the reps from autogylm showed it me..
  11. fossie
    fossie Member
    207
    Aye either the proper AG stuff or the bumper care stuff works really well
  12. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    i use a brush to apply my tyre shine to vehicles, much easier and no need to wash as its kept in its little box which is only for tyre shine.
    i use a mix of 2 products, ones a gel and the other is a spray, gives me a wicked shine and does last weeks.
  13. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Scrubbing the tyres with a stiff brush when washing will help any products stay put for longer.
    I used a small bit of sponge to apply Megs Endurance and its fine if the tyres have been cleaned first and not too much put on.
  14. 3DTDi
    3DTDi Member
    239
    Carplan Tyre Slik is a good value product, its spray on and shines for weeks and can be quite cheap, think morrisons do it in the petrol stations for about £3 a can, megs endurance gel in my experience does splatter dots up your sills if you use a fair bit of product
  15. kingtheydon
    kingtheydon New Member
    If your bothered about splatter then try FinishKare 108AS Tyre dressing.
    Leaves a Matt finish rather then a WET look. (I prefer the matt type look)
