A few faults
Agniusss Dec 3, 2012
  1. Agniusss
    Agniusss Member VCDS Map User
    35
    Hi. Any help is much appreciated
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Saturday,27,October,2012,19:56:57:26868
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    VIN: WAUZZZ4B92N093018 Mileage: 169050km/105042miles
    Address 01: Engine Labels: 06B-906-018-AWT.lbl
    Part No: 4B0 906 018 DC
    Component: 1.8L R4/5VT G 0001
    Coding: 11502
    Shop #: WSC 00499
    VCID: 65CB4C3EFF093230B23
    WAUZZZ4B92N093018 AUZ5Z0B0158064
    No fault code found.
    Readiness: 0110 1001
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 06275
    Shop #: WSC 00000
    VCID: 254B0C3EBF89F230723
    Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
    Part No: 4B0 820 043 AC
    Component: A6-Klimavollautomat 0105
    Coding: 00001
    Shop #: WSC 02325
    VCID: 5BBF6AC6C94D74C0147
    1 Fault Found:
    01592 - Air Quality Sensor (G238)
    57-00 - Electric Circuit Failure
    Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
    Part No: 4B0 959 655 M
    Component: Airbag 8.4E 4003
    Coding: 0001306
    Shop #: WSC 00028 021 00000
    VCID: 3A71CF4276376DC82F1
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 950 K
    Component: KOMBI+WEGFAHRS. M73 D02
    Coding: 00844
    Shop #: WSC 00000
    VCID: 2A51FF02D697DD485F1
    2 Faults Found:
    00849 - S-contact at Ignition/Starter Switch (D)
    30-10 - Open or Short to Plus - Intermittent
    01336 - Data Bus for Comfort System
    37-00 - Faulty
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 D
    Component: Zentralverriegelung D35
    Coding: 06881
    Shop #: WSC 02325
    4 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01562 - Right Rear Door
    59-00 - Can't Unlock
    01561 - Left Rear Door
    61-10 - Won't De-Safe - Intermittent
    61-00 - Won't De-Safe
    End ---------------------------------------------------------------------
    Thanks in advance
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    [h=2]01366 - Opened Due to Crash Signal[/h][h=4]Possible Causes[/h]
    • Output Test performed on Airbag Control Module (J234)
    • Vehicle involved in Accident
      • Airbag Control Module (J234) stored Crash Data
    • Wiring/Connectors from/to Airbag Control Module (J234) faulty
    [h=4]Possible Solutions[/h]
    • Check/Clear Fault Codes
    • Check Wiring/Connectors from/to Airbag Control Module (J234)
  3. gen.heinz guderian
    1,346
    126
    [h=2]00849 - S-Contact at Ignition/Starter Switch (D)[/h][h=3]00849 - S-Contact at Ignition/Starter Switch (D): Unknown Switch Condition[/h][h=4]Possible Causes[/h]
    • Terminal 15 OK, but Terminal S not OK
    • Fuse(s) faulty
    • Wiring/Connector(s) from/to Ignition/Starter Switch (D) faulty
    • Ignition/Starter Switch (D) faulty
    • Check Terminal S
    • Check Fuse(s)
    • Check/Repair Wiring/Connector(s) from/to Ignition/Starter Switch (D)
    • Check/Replace Ignition/Starter Switch (D)
  4. TYphoon GB
    TYphoon GB Active Member
    386
    26
    Have you cleared the faults and then rescanned?
    Are you shareware, full VCDS or paid software version.
    Flat battery can return random air bag, crash detection and other faults and may cause the ignition fault code.
    Did you have any DIS display warnings?
    Does the climate control work?
    If not may be old faults that were not cleared.
    I know its a pain but you could also try to clear faults in VCDS, then disconnect battery for 20 mins.
    Reconnect and rescan should reboot all the ECU's etc.
    Make sure you have radio code and know how to reset the clock and the windows :)
    After that any fault is probably valid and you can take all your christmas money to Audi for new bits....
  5. Agniusss
    35
    Yes I deleted and rescanned. I have full VCDS Ross tech. The battery is 1year old and have 5 years warranty (Bosch 780mah). No warnings. All climate control functions are working. Its not possible to delete these faults and I don't know why.? Radio is fittest not original. I fitted my self.
  6. TYphoon GB
    386
    26
    Crash signal should reset as a minimum.
    Suggest disconnect radio and repeat ....VCDS doesn't like aftermarket radios.
    I'd still pull the battery for a while as that should reset any old codes (some say 20 mins some 2 hours).
    If the radio install pick up on a live rather than the bus bar (does it stay on after the ignition is turned off but key still in?) that might explain some of the faults.
  7. Agniusss
    35
    No. It's starts from key ( ACC ) and off when you turn off the engine. I will try to delete all faults and don't start the engine and take out battery + let's say for two hours. I will try to do that first thing in a morning before I go to work and I will post again faults if there will be left :yes:
    P.S. Thanks
  8. Agniusss
    35
    Tuesday,04,December,2012,11:06:43:26868
    75 76 77
    VIN: WAUZZZ4B92N093018 Mileage: 170250km/105788miles
    Coding: 11502
    Shop #: WSC 00499
    1 Fault Found:
    18010 - Power Supply Terminal 30
    P1602 - 35-00 - Voltage too Low
    Readiness: 0110 1101
    Coding: 06275
    Shop #: WSC 00000
    Coding: 00001
    Shop #: WSC 02325
    2 Faults Found:
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    Coding: 0001306
    Coding: 00844
    Shop #: WSC 00000
    1 Fault Found:
    37-10 - Faulty - Intermittent
    Coding: 06881
    Shop #: WSC 02325
    5 Faults Found:
    00668 - Supply Voltage Terminal 30
    07-00 - Signal too Low
    01570 - Turn-Off Delay; Terminal 15
    29-10 - Short to Ground - Intermittent
    60-00 - Won't Safe
  9. TYphoon GB
    386
    26
    Stumped!
    It all points to low voltage to me....
    The door faults may be linked to the Convenience Module that suffers from damp issues.
    http://www.audi-sport.net/vb/a6-s6-allroad-forum-c5-chassis/92036-convenience-control-module.html
    Also lube the door lock catches as they signal the faults and rely on feeble micro switches.
    The air quality sensor only detects dirty air and switches to re circulation. Unless your driving in a coal mine or Chernobyl its probably useless. Some people report they go dead every 2-3 years.
    Expert needed....
  10. TYphoon GB
    386
    26
    Oh and a bit or research showed the air bag module is the crash detection signal source.
    How To: Airbag Control Module Replacement - AudiWorld Forums
    Might help....
    You might notice that all these bits are in or terminate in the radio location........... (smile?)
    Might be worth checking nothing has been disturbed...
  11. crazynorweegian
    crazynorweegian New Member
    I have thrown hundreds of dollars and over 60 hours at solving 01366. Airbag module, CCM, door latch modules, hatch latch module, battery, wiring, dome lights, puddle lights, foot well lights, harnesses, soft coding... finally someone told me to pull out my hazard light switch. Fixed.
  12. adamss24
    adamss24 Well-Known Member
    4,561
    395
    Thank you for sharing !
