A few 8L issues and questions, help welcome!
Max M4X WW Sep 8, 2013
  1. Max M4X WW
    Max M4X WW Member
    143
    Hi all,
    I'm a fairly new 8L owner, had it a couple of weeks and I have a few issues/questions if anyone is willing to help!
    1) The car has a rattle/knocking through the bulkhead at idle and low speeds, it goes away at speed and if you rev the engine slightly. It can't really be heard from outside the car as the noise seems to transfer through the car.
    2) The stereo has a high pitched squeak from the rear, its the amplified system but not Bose. The headunit is aftermarket. It isn't particularly loud but you can tell its there!
    3) Has anyone fitted an interior light from an A4 B5 like this one? It looks the same as the one I have but with the little red leds: 2000 AUDI A4 B5 AVANT ESTATE 2.4 V6 BREAKING INTERIOR LIGHT PANEL ONLY | eBay
    Thanks in advance!
  2. drewman
    drewman Member
    44
    1 & 3 not sure but point 2 can be a common problem with aftermarket headunits and amplified rears. You could try a different wiring harness but you may find you have other niggles such as popping when changing source etc
    Only way for perfection is to re-wire rear set-up!
  3. Max M4X WW
    Max M4X WW Member
    143
    It pops when it turns on too, to be honest I thought this may be the case and really want a factory CD headunit and USB input! Just need to find one that is in good condition and a suitable input adapter.
    Thanks!
  4. JudderMan
    JudderMan Well-Known Member
    1,026
    172
    1) Dogbone mount might be duff. If so, get a red diesel or yellow powerflex one. Do you get wheel hop if you accelerate quickly?
  5. Max M4X WW
    Max M4X WW Member
    143
    I did have a look at the dog-bone, looked ok but access wasn't great. It seems like there is too much movement or the mounts are all sagging so things are fouling, or something is falling off!
  6. <tuffty/>
    21,776
    4,165
  7. Max M4X WW
    Max M4X WW Member
    143
    I'm a bit OCD and would really like a factory light if possible!
  8. Max M4X WW
    Max M4X WW Member
    143
    Dogbone changed, still the same. Have been advised its my DMF? Sound likely?
  9. Big Al
    Big Al Active Member
    489
    68
    Yes, change the clutch too. Stick the car on a ramp, rev the engine whilst stationary to check for vibration. Any decent VAG tuner/garage should be able to diagnose & help.
  10. Max M4X WW
    Max M4X WW Member
    143
    I trust the guy who's looked at it, I'm just a bit annoyed with myself as it was fine two weeks ago when I bought it. Seems pointless to put a standard kit on too which is £330 when I can get an uprated one for £575. (Prices from Darkside Developments)
