A day on the car!!
Ash92 Mar 13, 2014
  1. Ash92
    Ash92 Active Member
    396
    29
    Evening all had a day of today so decided to black out the grill surround and detail the car for first time. What do you think of it?
    Ash
    warren_S5, THQuattro and V6 Quatt like this.
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado quattro Audi S4 Black Edition s tronic
    8,036
    2,484
  3. Ash92
    Ash92 Active Member
    396
    29
    That's tomorrow s job unsure what wing mirrors to have get the s4 ones or have matt black ones
  4. Skandz
    Skandz Member
    42
    what did you use to black out the trim?
  5. Ash92
    Ash92 Active Member
    396
    29
    Halfords bumper paint and gloss from b and m
  6. DieselJake
    DieselJake God Mode
    2,196
    395
    mancdan, Ash92 and jdp1962 like this.
  7. Skandz
    Skandz Member
    42
    ^^ LOL
  8. jdp1962
    8,036
    2,484
    Heheh!
  9. NOZ
    NOZ Member
    208
    21
    nice job thinking of doing mine what prep did you carry out, any undercoats etc and did you spray while still fitted to the car,
  10. Ash92
    Ash92 Active Member
    396
    29
    I took the surround of to do it and sanded the chrome a bit with I think.it was 1200grit a coat of primer which I.got from b and m 3 coats of colour then three coats of gloss
    If you can't be arsed doing that get a can of plasti dip and can spray while still on the car
  11. p1tse
    p1tse Member
    796
    24
    Good job
    Is the bonnet shut properly as the gap seems quite big or is it normal?
  12. Rastamouse
    Rastamouse Welsh Audi Nut
    379
    19
    Looks like the bumper needs adjusting after it was removed and refitted,easy job to adjust them.
  13. Ash92
    Ash92 Active Member
    396
    29
    I thought it was a bit unusual how do you adjust the height it been like that for a while now
  14. Rastamouse
    379
    19
    If u look on the slam panel by the inside of the headlight there you will see about a 18mm hole , if you look diwn this hole you should see a t30/t35 torx screw(there will be on on bith sides if slam panel), if my memory serves me right you need to turn these screws clockwise to raise the bumper and minimise the gap and counterclockwise to lower it. This is provided that you refitted the bumper correctly on to the adjustable properly. I did mine before i re tightened all the bolts on the bumper, but i believe it can be done without the bumper being loose,
  15. Ash92
    Ash92 Active Member
    396
    29
    Ok cheers for that I'll give it a blast in the morning
