A couple of questions about the s3 APY engine?
salisbury1985 Mar 25, 2013
  1. salisbury1985
    salisbury1985 Member
    Hi
    Firstly just wondered what boost these engines are capable of. I know when mapping its not all down to the boost as fueling etc has to be right but just wondered what boost they can generally run safely on a remap. Obviously no such thing as totally safe but you get what i mean.
    Second one is i found one of the crankcase breather hoses has split. The one which sits under the inlet, also the odd shaped one further along from this feels quite thin and seems like its not far off going. Ive read that its best to replace these with silicone items. Can someone point me in the right direction for the correct ones for my engine please.
    Thanks in advance
    Dan
  2. <tuffty/>
    20,839
    3,675
  3. salisbury1985
    Thanks for that, what would you reccomend boost wise on my setup. It has 3" downpipe, sportscat, s200 cone filter, forge recirc valve.
  4. <tuffty/>
    20,839
    3,675
    Don't get hung up on boost... its irrelevant... once its mapped properly then the boost will be what it will be.. the S3 with the B5 stage 2 in the link I posted was running less than 20psi to achieve 295hp with the right mods and a strong engine...
    There is no such thing as a boost table in ME7 tuning... boost is a means to an end... thats all...
  5. salisbury1985
    Fair play i get what your saying.
    Any ideas on where i can get the breather pipes for my engine?
  6. <tuffty/>
    20,839
    3,675
    Forge sell various hoses including the 3 way one off the cam cover (although I think its listed as a BAM engine code)... or do a full PCV delete and fit a catch can
  7. salisbury1985
    I did have a quick look at them but werent sure if it would fit as its for the BAM. Would this be ok then?
  8. <tuffty/>
    20,839
    3,675
    Its not a straight fit as the APY std one is different to AMK/BAM setups... Welly bought my old Forge one off me and fitted it to his APY... not sure what mods he did to get it to fit... they are all more or less the same engine underneath regardless..
  9. salisbury1985
    Ok ill have a word and see what he done to fit it to his. Would rather get it replaced with one that im not going to have to worry about again.
    Cheers for you help/advice.
