A/C Pressure Switch on a B6
Turkster mine the 1.9 but if it's the same mine was around £40 ish and if you drop passenger head light out you will see it straight underneath just fits in the side of the air con rad...assuming its the same.....
It is the same, on the nearside of the condenser, if you open the bonnet you'll see it.
Is yours leaking? I have had a leak for a while, so had the dye test done and my condenser is covered in green dye all down the one side!
is this the little BarStool ?
thats the 1
have u got a fault from vcds ?
thats the 1
No but my air con has never really been that great and there was a hissing noise coming from that area before that nobody could say what was making it, after doing some reading about this said switch and seeing that my air con has never been that great even after a full re gassing,
