A/C not working - Faults found:
Von Maximo Apr 27, 2008
  1. Von Maximo
    Von Maximo The Damned
    344
    My Aircon doesn't seem to work although my Heater does. Performed a scan but can not find the fault codes from the Fault code directory.
    Anyone shed some light on this for me? Or will I spend the summer being cooked alive! Please help save the life of a fellow Audi-sport member!!!!
    Address 01: Engine Labels: None
    Part No SW: 036 906 016 FF HW: 028 101 190 5
    Component R4 2,OL EDC G000SG 6337
    Shop #: WSC 0634
    2 Faults Found:
    18043 – Powertrain Data Bus: Missing Message from A/C Controller
    P1635 – 000- - - Intermittent
    Freeze Frame:
    RPM: 798 /min
    Torgue: 18.0 Nm
    Speed: 0.0 km/h
    Voltage: 14.29 v
    Bin. Bits: 11000000
    Bin. Bits: 00000000
    (No units): 0.0
    18049 – Please check DTC Memory of A/C Controller
    P1641 – 000 - - - Intermittent
    Freeze Frame:
    RPM: 798 /min
    Torgue: 20.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.14 V
    Bin. Bits: 11000000
    Temperature: 87.3°C
    (no units): 0.0
    Readiness: 0 0 0 0 0
    Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H30 0501
    Coding: 0488F2A214100000000000000000000
    Shop #: WSC 00000
    Part No: 8P2 955 119 C
    Component: Wischer WWS Audi350 0180
    Coding: 16187408
    Shop #: WSC 00000
    4 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    004 – No Signal/Communication - Intermittent
    01320 – Control Module for Climatronic (J255)
    004 – No Signal/Communication – Intermittent
    00483 – Control Module for Auxiliary Air Heater
    01431 – Control Module in Instrument Panel On Comfort Can (J285)
    I've cleared the faults and they haven't come back even though the Aircon still doesn't work but heater does
  2. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    What happens why you try to access 08-HVAC?
    -Uwe-
  3. Von Maximo
    344
    I can open it ok and no faults show. Performed an "Sequential output test - 03" and nothing jumped out at me apart from that I could hear and see everything working (Blowers, Flaps, Lighting etc) apart from when testing the coolant fan a warning came up saying that it would indeed test the fan by running it, Couldn't hear or see anything. Not to sure if anything was meant to happen?
    Was there anything else that I should have done in the 08-HVAC page?
    Found some more fault codes! lol
    VCDS Version: Beta 803.4
    Data version: 20080413
    Sunday,27,April,2008,15:47:10:13408
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 77 7D
    VIN: WAUZZZ8P35A006098 Mileage: 130580km/81138miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC G000SG 6337
    Revision: 12345678 Serial number: AUX7Z0D4FNO08T
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
    Component: KlimavollautomatH12 0150
    Revision: 007702 Serial number: 8P0820043F
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Revision: 00030000 Serial number: 00000000816024
    Coding: 04884F24A2141000000000000000000000
    Coding: 16187408
    Shop #: WSC 00000
    4 Faults Found:
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    00834 - Signal for Activation of Heated Rear Window
    009 - Open or Short to Ground - Intermittent
    00059 - Terminal 30 for Interior Lighting
    012 - Electrical Fault in Circuit - Intermittent
    00906 - Horn (H1)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000042
    Address 17: Instruments Labels: 8P0-920-xxx-17.lbl
    Part No SW: 8P0 920 980 P HW: 8P0 920 980 P
    Component: KOMBIINSTR. VDO H71 0200
    Revision: D01 Serial number: 2244DD01000045
    Coding: 0004408
    Shop #: WSC 00503 210 91504
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104521044E
    Coding: 3D0F0BCA070101
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D01 Serial number: AUX7Z0D4FNO08T
    Shop #: WSC 00212 210 63917
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H99 0550
    Revision: 12S Serial number: AUZBZ7G9908033
    Coding: 0205213
    Shop #: WSC 00212 210 91024
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 F
    Component: EPS_ZFLS Kl.10 1301
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 188000186D288F0F489AC63000
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001122899
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205213
    Address 77: Telephone Labels: None
    Revision: 00000001 Serial number: 00000000082747
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    End ---------------------------------------------------------------------
  4. Sebastian
    Sebastian Member
    286
    What values do you have in Measuring Value Block (MVB) 002 of the HVAC (#08) Control Module?
  5. Von Maximo
    344
    Info as requested:
    Address 08: Auto HVAC (8P0 820 043 F)
    18:05:04 Group 001: General
    0.000 A A/C Regulating Valve (N280)
    0.0 % A/C Regulating Valve (N280)
    21.0 % High Pressure Sensor (G65)
    6.0 bar Refrigerant Pressure
    18:05:04 Group 002: Compressor Shut-Off Conditions
    5.0 Current Shut-Off Condition
    1.0 Last Shut-Off Condition
    16.0 Last but One Shut-Off Condition
    79.0 Last but Two Shut-Off Condition
    18:05:04 Group 003: Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
    28.0 Feedback Value (Actual)
    29.0 Feedback Value (Specified)
    32.0 Minimum Position (Lower Stop/Cool)
    221.0 Maximum Position (Upper Stop/Hot)
  6. Sebastian
    Sebastian Member
    286
    Odd, haven't seen the conditions 16 and 79 before and they are not documented either. However, the values you posted were taken with the engine off, could you do the same (i.e. MVB 001 & 002) with the engine running so that the A/C could try to start?
  7. Von Maximo
    344
    Engine running and A/C set to minimm temp and blower Max. STill got the 16 and 79 values on 002 what ever they are?
    19:05:00 Group 001: General
    0.640 A A/C Regulating Valve (N280)
    58.0 % A/C Regulating Valve (N280)
    20.5 % High Pressure Sensor (G65)
    5.0 bar Refrigerant Pressure
    19:05:00 Group 002: Compressor Shut-Off Conditions
    0.0 Current Shut-Off Condition
    19:05:00 Group 003: Left Temperature Flap Control Motor (V158) / Potentiometer (G220)
    167.0 Feedback Value (Actual)
    166.0 Feedback Value (Specified)
    Sunday,27,April,2008,19:06:26:13408
  8. Sebastian
    Sebastian Member
    286
    Shut-Off Condition indicates that the compressor is running, also the related values appear fine. It should give you cool air based on what I see.
  9. Von Maximo
    344
    Think it could be something Mechanical then? All I know is that it's defenitely not working as I've been roasting my nuts of all week!
  10. Sebastian
    Sebastian Member
    286
    The roasting issue might be related to your seat heating... ;)
    Seriously, based on what I see it "should" work unless I miss something obvious.
  11. aeroelastic
    aeroelastic Member
    45
    Hi I know this is old, did you get this sorted? I have a very similar issue. Thanks.
