** 99 S3 Starting problems **
miss_lucy Aug 27, 2012
  1. miss_lucy
    miss_lucy Its me Juicy - L8 JCY
    117
    Hi,
    Every now and again my S3 won't start or i need to give it some revs to start, but when it generally does start it starts perfectly.
    When it has problems starting theres a really rich fuel smell aswell.
    anyone have any ideas, fuel pump, injectors????
    Lucy
  2. Greg-S3
    Greg-S3 Active Member
    576
    67
    Have you had a look at the throttle body? Cleaned it and had it reset? Has the car been scanned for faults? Smoke tested for air leaks?
  3. aragorn
    18,665
    880
    scan for codes for a start
    What does it do when it fails to start? Does it just crank over endlessly? Does it fire up then cutout straight away? Or maybe it coughs and splutters but never quite catches?
  4. Gops
    3,198
    666
    Mine does it when the tank is below 1/4. But starts the second time. I think it could be a slowly dying fuel pump!
  5. miss_lucy
    117
    It just cranks over endlessly!
  6. Greg-S3
    576
    67
    Crank sensor
  7. cjsuk
    cjsuk Active Member
    567
    80
  8. miss_lucy
    117
