99 QTS EML on.
Y83OLK Apr 30, 2010
  1. Y83OLK
    Y83OLK Hulk Smash!
    841
    Hi all.
    Just popped round to a friends to diagnose his Engline Management light on.
    Vagcom codes are:
    17536 - Fuel Trim: Bank 1 (Mult): System too Lean
    P1128 - 35-00 - -
    17705 - Pressure drop between turbo and throttle valve (check DV)
    P1297 - 35-10 - Intermittent
    Runs/ drives fine... Theres a fluttering around the DV area when the throttles let off. Like a pidgeon.
    Any one else recon its a knackered DV diaphram?
    Just After some confirmation before i order him a forge.:idea:
  2. finesse
    finesse Active Member
    2,805
    Welcome to the evil 17705 and 17545
    If it is the original Bosch DV, then it is prone to failure.
    You need to go back and take vagcom logs of engine blocks 02, 031 and 115. tufftybloke can read whats going on
  3. Y83OLK
    Y83OLK Hulk Smash!
    841
    Usually i would have done.. However, I forgot to charge the lappy :(
    I checked the usual pipes for splits, had a general listen around for hissing... But the only thing i could find was the fluttering sound .
    Ive got a spare Dv in my toolbox, so ill bung that on tomorrw and give it a try i think.
  4. Prawn
    11,510
    3,425
    fluttering is definately a broken DV
